Abyrax ®   06-Jun-2024 07:43
GPS Test
Year: 2024
Version: 1.6.5
Developer: Chartcross Limited
Platform: Android
Localization: English
Crack: Premium Unlocked
Description: This app will allow you to view additional GPS and sensor data, check your location’s GPS reception and refresh AGPS data for quicker fix times. You may check your altitude, the time (both UTC and your local time), the direction you’re headed, the moon phase, and the time of day, all from within the app. It is compatible with global navigation satellite systems such as GPS, GLONASS, GALILEO, SBAS, BEIDOU, and QZSS. The app’s color palettes, which include a night mode, are customizable to suit your preferences. The color schemes can be used to coordinate the app with other devices.
Additional info: HOW-TO: How to test and improve GPS signal reception on your Android phone
If you often face the fact that your phone does not detect your GPS location well, then do not rush to scold the developers of the navigation application. Most likely, the problems lie in the reception of GPS signal and installation of satellites. You can test the quality of receiver work with the help of special utilities.
GPS Test has many different features, including getting information about the number and position of satellites, checking the positioning accuracy, displaying geographic coordinates, compass and displaying a bunch of other information like speed, altitude and even the time of sunrise and sunset at the current location.
In addition, the programme draws various graphs like signal strength changes and movement of the positioning point in real time. With GPS Test you can see how many satellites the device is really able to hold and at what signal strength.
I suggest to start diagnostics of the receiver with a trivial thing - check if it is enabled in the settings. Then update the A-GPS cache and clear it if necessary. The application allows you to calibrate the compass and accelerometer. Note that you will need an internet connection to work.
Just in case I remind you that it is useless to test GPS in a room without windows or far away from them. If you don't want to go outdoors, it is better to put the phone on the windowsill. Powerful electrical appliances working nearby can also interfere. And here's another trick: sometimes it helps just to turn the phone a few times a full turn.
Springer Handbook of Global Navigation Satellite Systems - Various Authors [2017, PDF]
An Introduction to GNSS, GPS, GLONASS, BeiDou, Galileo and other Global Navigation Satellite Systems...
Global Navigation Satellite Systems, Inertial Navigation, and Integration - 4th Edition - Grewal, An...
Introduction to GNSS - Pennsylvania State University [2018, PDF]
GNSS – Global Navigation Satellite Systems GPS, GLONASS, Galileo, and more - Bernhard Hofmann-Wellen...
Global Navigation Satellite Systems - Jin Shuanggen [2012, PDF]
System of Differential Correction and Monitoring. SDCM, Interface Control Document, Radiosignals and...
Understanding GPS/GNSS | Principles and Applications - Elliott D. Kaplan, Christopher J. Hegarty [20...
Simrad GPS Compass User Manual (HS70, HS75, HS80A, MX575D, HS80A, MX575D) - Navico Holding AS [2019,...
Thrane & Thrane - BGAN-Explorer-325 Installation and User Manuals - Thrane & Thrane A/S [2015, PDF]
The time now is: Today 23:46
