sugarspicesatya ®   23-Apr-2024 05:34
Pumps as Turbines - Fundamentals and Applications
Year: 2018
Author: Armando Carravetta , Shahram Derakhshan Houreh , Helena M. Ramos
Genre: Technical book
ISBN: 978-3-319-67506-0, 978-3-319-67507-7
Pages count: 226
Description: The topic of the book is introduced, based on existing power plants and
machinery, and the main definition of hydropower technology is given. Power
plants are differentiated in terms of plant size, stream characteristics and field of
application, and the design constraints in energy production within pressurized
networks are described. In this chapter, specifically, conventional hydro turbines
applied in micro/pico-hydropower stations are presented. The pump, as an effective
alternative device operating as a turbine, is introduced and compared with more
expensive conventional turbines. Finally, the field of application of the pump as a
turbine (PAT) is presented and discussed. The reader will be introduced to the
particular characteristics of small hydropower plants and will become acquainted
with the terminology used by professionals. In particular, he/she will be made
aware of the specific problem of energy recovery in water distribution networks for
different industrial sectors.
Pumps as Turbines - Springer.pdf
Download [14 KB]
Power Transformers - Principles and Application - J.Winders [2002, PDF]
Power plant centrifugal pumps - Maurice.L.Adams [2017, PDF]
Fundamentals of Fluid Mechanics - Bruce R. Munson [2013, PDF]
The Centrifugal Pumps - Grundfos [2012, PDF]
Principles of Naval Engineering: Propulsion and Auxiliary Systems - Matthew A. Carr [2012, PDF]
Marine Renewable Energy Handbook - Multon B. [2012, PDF]
VFD Challenges for Shipboard Electrical Power System Design - Mohammed M. Islam [2019, PDF]
Marine Machinery - Liviu Constantin Stan (Nautica) [2010, PDF]
Design of Propulsion and Electric Power Generation Systems - Woud H.K, Stapersma D. [2003, PDF]
Modern Marine Engineer’s Manual Volume 1 - Everett C. Hunt [2010, PDF]
The time now is: Today 14:21
