zxc ®   10-Apr-2024 16:47
The Oilfield Seamanship Series: Volume 4 | Towing
Year: 1994
Author: Michael Hancox
Genre: Textbook
Publisher: Oilfield Publications
ISBN: 1.870945 638
Pages count: 516
Description: This fourth volume of the Oilfield Seamanship series is primarily for personnel serving on or utilizing the specialist tugs and anchor handling vessels found in the offshore oil industry.
As the same vessels may change rapidly from a lowing to an anchor handling operation the hook should he read in conjunction with Volume 3 which covers anchor handling.
I'm use of oilfield towing anchor handling tugs by barge masters and those in charge of drilling units, work barges and other specialist vessels will be found by reference to Volume 5 which covers barge moving and mooring.
Section 13 of Volume 3, Anchor Handling, covering boat handling, is applicable both parts of this book. In common with most branches of seamanship the techniques and methods described arc not the only ones that are in use. Particular circumstances, equipment or operations may require considerable modification of the methods described.
I am greatly indebted to many masters and others engaged in offshore oil industry towing and anchor work, too numerous to name, but many of these will recognize their techniques which have been credited where appropriate.
Towing - Hancox.pdf
Download [13 KB]
The Oilfield Seamanship Series: Volume 3 | Anchor Handling - Michael Hancox [1996, PDF]
The Oilfield Seamanship Series: Volume 2 | Jack-UP Moving - Michael Hancox [1993, PDF]
The Oilfield Seamanship Series: Volume 5 | Barge Moving - Michael Hancox [2011, PDF]
Anchor Handling Tug Operations - I.Clark & M.Hancox [2012, PDF]
The Oilfield Seamanship Series: Volume 1 | Rescue Towing - Michael Hancox [2007, PDF]
International Guidelines for the Safe Operation of Dynamically Positioned Offshore Supply Vessels - ...
Advanced Stability - The University of Texas at Austin [2006, PDF]
Towing operations - International Maritime & Offshore Safety Training Institute [2015, PDF]
Working with tugs [2008, PDF]
The time now is: Today 02:56
