gillnumil ®   05-Apr-2024 04:57
Expire Date Monitor
Year: 2024
Version: 1.5.8
Developer: Yury Komar
64-bit OS compatibility: yes
Localization: English
Crack: Not needed
Description:
• Keep records of all your certificates in one place
• Attach files/scans of your document (support any type of file)
• Open the files right from the app's window by clicking on corresponding button or a double click on selected row in the table
• Show expiration warning label on the bottom with count of documents to be renewed
• Separate documents by the groups (to be created/selected while adding/editing of the document data)
• Export table to Excel
• All data and files saved to own database and will never be lost even if you delete original files from computer
• Sorting of the table also will be saved once you click to the table columns and on next application run you will see your sorted data, as it was before closing the application window
• Possibility to set you own label with expire days
Changelog:
1.5.2
✨ Some minor improvements.
✅ Added saving of table sorting while click on table columns headers.
1.5.5.
✅ Added a couple more labels along the lines of expiration of documents (1 month and 2 weeks).
1.5.6:
✅ Added: Option to set your custom label and color to highlight documents with your own value of Days Left till expiration.
If option is enabled, all standard labels will be hidden but your will be visible instead.
1.5.8:
Fixed: Issue with date format leading to the wrong calculation and does not saving the dates at all.
Additional info: Made with in Vladivostok.
Please support the project: http://sea-soft.ru/donate.html
If any application from Sea-Soft Project has helped you with routine job or simplifying any other tasks, consider supporting its continued development with a small donation! ????
Any donations large or small are greatly appreciated :)
A massive THANK YOU to everyone who's already donated and supported the coding! ☕️
SOS Donate (https://t.me/tribute/app?startapp=deT5) (EUR via Telegram)
SOS Donate (https://boosty.to/sea-soft/donate) (Any via Boosty)
SOS Donate (https://www.sberbank.com/sms/pb...ber=79140787339) (RUB via Sber)
(https://t.me/SeaSoft_by_YuryKomar/24/3558)
Expire Date Monitor.exe
Download [656 B]
Sea Service Calculator v.1.5.6 - Yury Komar [2025]
Wind Calculator v.3.0.0 - Yury Komar [2024]
ETA Calculator v.1.3.0 - Yury Komar [2025]
ETA Calculator v.2.1 - Yury Komar & Mikhail Mishabar [2025] [Android]
IMPA Desktop v.1.3 - Yury Komar [2025]
ECDIS Route Manager 1.9.06.9625 (09.05.2026)
BAPLIE Manager v.1.0.5 - Yury Komar [2024]
Anschutz Radar Map Manager v.1.0.0.9209 - Yury Komar [2025]
ДЕЛЬТА ТЕСТ. КОНВЕНЦИЯ + " КАПИТАН " v.1.0.0 - Yury Komar [2024]
Marinepedia v.3.0.1 - Sumanjay [2022] [Android]
The time now is: Today 18:59
