vitbar192 ®   16-Mar-2024 16:39
Knots & Their Uses
Year: -
Author: -
Pages count: 28
Description: Knots & Their Uses
• a good knot holds but is easy to open if necessary
• there are different knots for different purposes and all knots are not good for all purposes
• practice makes perfect
• a good knot needs not to be complicated, use the simplest one good enough for the job
• there is a difference in situations where there is constant pull on the rope or if it is sometimes loose and sometimes taut
• sometimes it is important to be able to open the knot, even if there is a heavy load on the line
• learn the difference of the wrong way to do it and the right way to do it, especially how the wrong way to do it causes the knot to slip or makes it difficult to open
Knots & Their Uses.pdf
Download [1 KB]
Essential Knots Made Simple: A Visual Guide to Knot Tying for Outdoor Adventures, Emergency Use, and...
Knot Tying Made Easy - Prince C. [2020, PDF/EPUB]
Knots - an Illustrated Practical Guide to the Essential Knot Types and Their Uses - Adamides A. [200...
Knots and how to tie them - Boy Scouts of America [1969, PDF]
A Primer on Knots, Hitches, and Bends - Kauffman R.B. [2015, PDF]
Knot Tying for Beginners: An Illustrated Guide to Tying 25+ Most Useful Boating Knots - Matthew McCo...
Basic Tie Knot: A Complete Step By Step Knot Tying Picture Guide With Survival Roping Techniques And...
Tying Different Types of Knots - Essential Knots You Should Know - Outdoors [2021, PDF]
Tying Knots for Beginners - How to Tie Types of Knots for Beginners - Essential Knots You Can Do - O...
Encyclopedia of knots and fancy rope work - John Hensel, Raoul Graumont [1984, PDF]
The time now is: Today 09:08
