vitbar192 ®   07-Mar-2024 13:57
Reeds Outboard Motor Troubleshooting Handbook
Year: 2013
Author: Pickthall B.
Publisher: Bloomsbury Publishing
Format: PDF/EPUB
Pages count: 126
Description: Most outboard motors will be troublesome at some point in their lives, but armed with the right knowledge a skipper needn't worry. The Reeds Outboard Motor Troubleshooting Handbook is a compact, pocket-sized guide to finding solutions to all of the most common outboard problems, and many of the less common ones too. The perfect format for quick reference on board, this book will help skippers fix troublesome outboards themselves, or enable the skipper to do an emergency patch-up for a more serious problem until they can get back to port. Each topic addresses a particular problem, and gives clear step by step instructions with helpful colour photographs and diagrams showing exactly what to do. Straightforward and accessible, the Reeds Outboard Motor Troubleshooting Handbook should be an essential part of any skipper's DIY toolkit - and perfect for slipping in the pocket.
Pickthall B. Reeds Outboard Motor Troubleshooting Handbook, 2013
Download [29 KB]
REEDS Diesel Engine Troubleshooting Handbook - Barry Pickthall [2013, EPUB]
REEDS First Aid Handbook - Martin Thomas, Olivia Davies [2024, EPUB/PDF]
AC Maintenance & Repair Manual for Outboard Motors - Pallas J.L. [2014, PDF/EPUB]
REEDS Skipper’s Handbook For Sail and Power - Pearson M. [2016, EPUB]
REEDS Skipper’s Handbook For Sail and Power - Pearson M. [2020, EPUB]
REEDS Skipper’s Handbook - Malcolm Pearson [2010, PDF]
Maintenance and Repair for Outboard Motors - Jean Luc Pallas [2013, EPUB]
REEDS Weather Handbook - Frank Singleton [2019, PDF]
REEDS Marine Distance Tables - Miranda Delmar-Morgan, Kendall Carter [2024, PDF]
Reeds Cloud Handbook - Oliver Perkins [2022, EPUB/PDF]
The time now is: Today 00:24
