namemamun ®   23-Dec-2023 11:13
Pistons and engine testing
Year: 2016
Author: MAHLE GmbH
Genre: Handbook
Publisher: Springer
Pages count: 305
Description: This is the second revised edition of the second volume of the MAHLE Knowledge Base, a
multivolume set of technical books.
The volume “Pistons and engine testing” expands on and adds greater depth to the first
volume, “Cylinder components”. In this book, MAHLE experts share their broad-based,
extensive technical knowledge of pistons, including layout, design, and testing. The large
number of pictures, charts, and tables provide a good visual overview of the entire subject,
making your day-to-day work in this field easier.
Never before have such high and sometimes contradictory demands been placed on
modern engines, and therefore on their pistons, by international legislation as well as customers.
Therefore, the following pages are filled with detailed information on everything to do
with pistons: their function, requirements, types, and design guidelines, as well as simulation
of operational strength using finite element analysis, and piston materials, cooling, and component
testing. Engine testing is, however, still the most important element in component
development, as well as for validating new simulation programs and systematically compiling
design specifications. In the meticulous scientific depth you have come to expect, you will
find out more in the detailed section “Engine testing”.
This second volume in the series of technical books is again primarily intended for engineers
and scientists in the fields of engine development, design, and maintenance. However, professors
and students in the subjects of mechanical engineering, engine technology, thermodynamics,
and vehicle construction, as well as any readers with an interest in modern
gasoline and diesel engines, will also find valuable information on the following pages.
Pistons and engine testing.pdf
Download [15 KB]
Diesel Engine Management: Systems and Components - Konrad Reif [2014, PDF]
Handbook of Offshore Engineering Volume 1 - Subrata k Chakrabarti [2006, PDF]
Radar Technology Encyclopedia - David K.Barton et al. [1998, PDF]
Marine Nuclear Power Technology - Yu J. [2020, PDF]
Large Floating Structures - Technological Advances - C.M. Wang, B.T. Wang [2015, PDF]
The Facts on File Marine Science Handbook - McCutcheon S. @ B. [2003, PDF]
Sensors and Transducers - Ian Sinclair [2001, PDF]
Practical design of ships and other floating structures volume 2 - Tetsuo Okada , Katsuyuki Suzuki ,...
Supercargo Operations - An Introduction - Mike Wall [2020, PDF]
Damage to Engine Bearings - MS MotorService International GmbH [2017, PDF]
The time now is: Today 11:25
