namemamun ®   27-Nov-2023 20:50
AWS D1.1/D1.1M:2010-Structural Welding Code— Steel
Year: 2010
Author: AWS
Pages count: 569
Description: This code covers the welding requirements for any type of welded structure made from the commonly used carbon and
low-alloy constructional steels. Clauses 1 through 8 constitute a body of rules for the regulation of welding in steel
construction. There are nine normative and twelve informative annexes in this code. A Commentary of the code is
included with the document.
AWS D1.1D1.1M-2010 Structural Welding Code-Steel.pdf
Download [13 KB]
AWS-D1.2-2014-structural-welding-code-aluminum - AWS [2014, PDF]
ISO 18119:2018 - Gas cylinders – Seamless steel and seamless aluminium-alloy gas cylinders and tubes...
Guidelines for Hull Monitoring - ClassNK [2021, PDF]
Underwater Welding of Offshore Platforms and Pipelines - American Welding Society [1981, PDF]
Marine Chain Cable Pocket Guide - Lloyd’s Register [2011, PDF]
Requirements of Liquefied Carbon Dioxide Carriers - ABS [2024, PDF]
BV - Rules for the Classification of Steel Ships - PART A – Classification and Surveys - 2021 - BURE...
Requirements for Application of Higher-Strength Hull Structural Thick Steel Plates in Container Carr...
Guide for liquefied Gas Carriers with Independent tanks November 2019 - ABS [2019, PDF]
The time now is: Today 03:47
