Muhammad Ellatakany ®   05-Jun-2023 13:04
Confined Space Safe Practice
Year: 2019
Author: VAR
Quality: OCR without errors
Pages count: 66
Description: At the back of this guide, there are six attachments intended to further assist employers who are starting to learn about confined spaces or for those who wish to improve an existing program. Attachments A through D provide samples of hot work and permit-required confined space entry forms, SDS, atmospheric monitoring equipment information, and general testing protocols. Attachment E, “Setting Up a Permit-Required Confined Space Program,” contains easy, step-by-step instructions for required and suggested actions in the implementation of a confined space program that meets regulatory requirements. Attachment F, “Permit-Required Confined Space (PRCS) Decision Flow Chart,” helps employers to determine the required entry procedure as defined by the confined space standard.
This guide does not list every conceivable confined space hazard. It is not intended as a legal interpretation of federal or state standards and should not be used as a substitute for training
Regulatory Requirements 1 ....................................................................................................................
Introduction 2 ..........................................................................................................................................
Fatal Facts 4 .............................................................................................................................................
Rescue 5 ....................................................................................................................................................
Emergency 6 ........................................................................................................................................
Self-Rescue, Non-Entry, and Entry Rescue 7 ......................................................................................
Rescue Training and Plan 8 .................................................................................................................
On-Site Rescue Team vs. Off-Site Rescue Team 9 ..............................................................................
Rescue Equipment 11 ..........................................................................................................................
Definitions and Basics 13 ........................................................................................................................
General Terminology Confined Space; Immediately Dangerous to Life or Health (IDLH); Permissible
Exposure Limits (PEL); Entry
14 ......................................................................................................................
Permit Evaluation Permit-Required vs. Non-Permit Confined Space; Space Reclassification;
Alternate Procedures; Permit-Required Confined Space Program (Hot Work and Host Employer-Contractor)
17 ...........................................................................................................................
Confined Space Hazards 24 ....................................................................................................................
Atmospheric Hazards Oxygen Deficiency/Enrichment; Combustible/Flammable/Explosive Gases and Vapors; Combustible Dust; Toxics; Safety Data Sheets (SDS); Monitoring-Air Sampling and Equipment
25 .....................................................................................................................
Physical Hazards Mechanical; Entrapment; Engulfment; Other Types of Hazards
33 .............................................................................................................................
Hazard Controls 35 ................................................................................................................................
Controls for Atmospheric Hazards Ventilation; Respiratory Protection; Other Control Measures
36 .................................................................................................
Controls for Physical Hazards Isolation (Mechanical, Electrical, Pressurized Lines, Ducts, or Pipes); Other
Control Measures
38 ........................................................................................................
Personal Protective Equipment and Tools 40 ......................................................................................
Communication System 41 ..................................................................................................................
Confined_Space_Guide_for_General_Industry_Cal_OSHA_May_2019.pdf
Nebosh- Igc, Element-6, Hazards Control System & Safety Proc [2021, MP4]
Confined Space Entry [2024, MP4]
Confined Space Safe Practice, Rev. 3 - IACS [2018, PDF]
Confined Space Safe Practice (Rec.72) - IACS [2025, PDF]
CBT-0387 Enclosed Space Entry, Hazard Awareness and Preparations for Entry - Seagull [2025, JPEG]
HSE Brief Safety Guides - HSE [2005, PDF]
Oil Tankers - A pocket Safety Guide - Witherby Seamanship [2015, PDF]
Introduction to Confined Space Assessment (Theory) [2022, MP4]
Confined Space (CS) Trained [2024, MP4]
Scissor Lift Certification [2023, MP4]
The time now is: Today 16:47
