gillnumil ®   01-Jun-2023 07:55
Testo 350 Maritime V2 · Flue Gas Analyzer: Instruction Manual
Year: 2016
Author: Testo
Pages count: 104
Description: The testo 350 MARITIME is a portable flue gas analyser, which can be used as a system component within a complete monitoring system to measure flue gas emissions from marine diesel engines in accordance with MARPOL 73/78 Annex VI and NOx Technical Code 2008 (MEPC.177(58)). In order to fully comply with the on-board detection procedure of the “Direct Measurement and Monitoring Method” MARPOL 73/78 Annex VI and NOx Technical Code 2008 (MEPC.177(58)), additional parameters must be recorded.
The flue gas analyser testo 350 MARITIME is certified by DNV GL for measuring gaseous flue gas components as a system component (e.g. for the “direct measurement and monitoring” on board procedure, and for simplified measurement procedures).
testo-350-Maritime-Instruction-Manual.pdf
Download [9 KB]
Guide to oil in water monitoring & discharge - Rivertrace [2021, PDF]
Procedures for the Control of Sulphur Oxide (SOx) Emission in Emission Control Areas (ECA) -…
Guidelines Addressing Additional Aspects Of The Nox Technical Code 2008 With Regard To Particular…
Rapid Response Damage Assessment program (RRDA) User Manual - Gas Carrier - ABS [2021, PDF]
YANMAR Diesel Generators: M6EY18AL-ALV, M6N21L-V, M6N165L, M6NY16L (manuals + video) - maintenance…
British Pioneer - IMO 9180140 - Machinery Operating Manual - unknown [1999, PDF]
NAVTEX Manual (2023 Edition) - IMO [2023, PDF]
User’s Guide PMI System (On-line) Pressure Analyser Version 2.0 - MAN B&W Diesel A/S [2001, PDF]
Oil record Book, part I and II (with examples) - Novomar Assesoria Empresarial Ltda [20??, PDF]
Clean Seas Guide for Oil Tankers - OCIMF [1994, PDF]
The time now is: Today 14:13
