Year: 2022 Language: english Playtime: 20h 17m Quality: WEB-DL Format: MP4 Video: H.264 1280x720 30 fps Audio: AAC 48.0 KHz x 320 Kbps Description: A compelete understanding of pumps & compressors used in process industries for a successful operation of your facility What you'll learn Understand rotating equipment working principles for successful operation of your plant and piping systems Understand the various rotating equipment construction details Lear how to read and interpret pump and compressor curves Learn how to determine and interpret your piping system curve Optimize the operation efficiency of your pumping and/or compression systems Perform various calculations to size and assess rotating equipment performance (head, discharge temp, inlet capacity, volumetric efficiency…) Understand what affects the selection and design of rotating equipment (process conditions, fluid characteristics, interstaging, foundation needs...) Understand the concept of pulsation, how it can affect your compressor performance and how to control it according to the API 618 standard Know how to size suction and discharge volume bottles to control reciprocating compressor pulsation Analyze the problems in operation related to packing, mechanical seals, bearings and flow control Apply the best practices and guidelines for maintenance, problem solving and troubleshooting of rotating equipment Be an active and efficient communicator during meetings with rotating equipment vendors Test your knowledge with 500+ question quiz Get access to useful charts and diagrams to solve daily rotating equipment problems Download our valuable Compressor Performance Excel Workbook And much more... Requirements Some engineering or field knowledge is preferable but not mandatory. All the concepts are explained in depth using an easy to understand language to allow students to build their knowledge from the ground up Having attended our "Flow of Fluid Through Piping systems" online course is a plus but not mandatory Description Rotating equipment of various designs and applications are encountered nowadays throughout refining, petrochemical and process industries as well as in power generation and environmental engineering. This 20H masterclass is designed to provide you with a complete understanding of construction details and functioning of Pumps Centrifugal compressors Reciprocating compressors This understanding is a prerequisite for a successful and flawless operation of your plant and piping system. This 20H masterclass includes extensive graphics, 3D animations and cross-sectional views to give you a virtual practical exposure on rotating equipment. The objective of this masterclass is threefold 1. Break down for you all the pumps, centrifugal compressor and reciprocating compressors operating principles into easily digestible concepts like Cavitation Performance curves Fluid Head Net Positive Suction Head, NPSH System resistance Surge and Stonewall Capacity control Pulsation control Lubrication Cooling ... 2. Illustrate through 3D animations and cross-sectional views the main rotating equipment mechanical components, state their function and operating limits, like Impellers Bearings Mechanical seals Packing Crossheads Pistons Compressor valves ... 3. Provide guidelines and best practices for operation, maintenance and troubleshooting of rotating equipment in accordance with the latest API Standards Also included in this masterclass 2 valuable Excel Workbook Centrifugal Compressor Performance Excel Workbook Pump Calculations Excel Workbook These workbooks provide qualitative and quick comparisons and application notes for centrifugal compressors and pumps. They describe calculations and procedures to predict performance characteristics, especially head, discharge pressure and power. So with no further ado, check out the free preview videos and the curriculum of the course and we look forward to seeing you in the first section. Hope to see you there WR Training Spread the wings of your knowledge NOTE : These Excel workbooks include Visual Basic for Application function subroutines. Macros must be enabled for them to work ------------------------------------------------------------------- INSTRUCTION TO DOWNLOAD THE EXCEL WORKBOOKS 1. Upon enrolling in, expand the last section "DOWNLOADABLE RESOURCES" 2. Under the lecture "Download me", click on the folder "Resources" => A list of downloadable files will appear 3. Click on any of the Excel Workbook files 4. A download window will pop-up. Select the location where you want to save the Excel file 5. Once downloaded and saved on your computer, you can start using these valuable Workbooks DISCLAIMER These Excel Workbooks are provided by WR Training "as is" and any express or implied warranties, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose are disclaimed. In no event shall the Copyright owner or contributors be liable for any direct, indirect, incidental, special, exemplary, or consequential damages (including, but not limited to, procurement of substitute goods or services, loss of use, data, or profits, or business interruption) however caused and on any theory of liability, whether in contract, strict liability, or tort (including negligence or otherwise) arising in any way out of the use of these Excel Workbooks, even if advised of the possibility of such damage. Who this course is for Chemical, Process and Mechanical Engineers Product Engineers and Technologists Operation, technical service and maintenance professionals Engineers, Consultants and Sales professionals Technical professionals responsible for piping system inspection Technical professionals responsible for interdisciplinary energy projects
Rotating Equipment Masterclass Pumps & Compressors
Playtime: 20h 17m
Quality: WEB-DL
Format: MP4
What you'll learn
And much more...
Requirements
Description
Pumps
Cavitation
Performance curves
Fluid Head
System resistance
Surge and Stonewall
Capacity control
Pulsation control
Lubrication
Cooling
Impellers
Bearings
Mechanical seals
Packing
Crossheads
Pistons
Compressor valves
WR Training
DISCLAIMER
Rotating Equipment Masterclass Pumps & Compressors.rar
Download [12 KB]
Share
Share
Share
