5sb1 ®   16-May-2023 08:52
Engineering Mathematics for Marine Applications
Year: 2023
Author: Umesh A. Korde, R. Cengiz Ertekin
Genre: Methodological guide
Publisher: Cambridge University Press
Pages count: 428
Description: Gaining expertise in marine floating systems typically requires access to multiple resources to obtain the knowledge required, but this book fills the long-felt need for a single cohesive source that brings together the mathematical methods and dynamic analysis techniques required for a meaningful analysis, primarily, of large and small bodies in oceans. You will be introduced to fundamentals such as vector calculus, Fourier analysis, and ordinary and partial differential equations. Then you'll be taken through dimensional analysis of marine systems, viscous and inviscid flow around structures surface waves, and floating bodies in waves. Real-life applications are discussed and end of chapter problems help ensure full understanding. Students and practicing engineers will find this an invaluable resource for developing problem solving and design skills in a challenging ocean environment through the use of engineering mathematics.
Engineering Mathematics for Marine Applications.pdf
Download [13 KB]
Mathematical Techniques for Wave Interaction with Flexible Structures - Trilochan Sahoo [2013, PDF]
Atmospheric and Oceanic Fluid Dynamics - Fundamentals and Large-Scale Circulation - Vallis G.K.…
Advanced Engineering Mathematics 7th Edition - Dennis G. Zill [2020, EPUB]
Fluid Mechanics for Engineers - A Graduate Textbook - Meinhard T. Schobeiri [2010, PDF]
Ocean Waves and Oscillating Systems: Volume 8: Linear Interactions Including Wave-Energy Extraction…
Numerical Methods in Fluid Dynamics - Gary A. Sod [2009, PDF]
The Principles of Naval Architecture Series - Various Authors [2008-2010, PDF]
Mechanical Vibrations: Theory and Applications, SI - S. Graham Kelly [2012, PDF]
Global Strength of Ships - Analysis and Design using Mathematical Methods - Caridis P.A. [2025, PDF]
The time now is: Today 15:08
