vitbar192 ®   30-Apr-2023 19:43
Dynamic Positioning Theory & Practices
Year: 2018
Author: Shukla K.C.
Genre: Technical book
Publisher: Witherbys
ISBN: 9781856099363
Pages count: 206
Description: Dynamic positioning is a complex subject with a wide range of systems and applications. This book comprehensively explains DP principles and procedures for all users, reinforcing the theory throughout with full-colour illustrations and photographs.
The publication is divided into the following sections:
THE THEORY OF DYNAMIC POSITIONING
This section describes the components and controls of a DP system and illustrates different system layouts and configurations. It looks in detail at position measurement, position keeping, system tests, Class requirements and the functions available to the DP operator. It also describes planning of a DP operation, including risk assessment, operational considerations, safety features and contingency plans.
EQUIPMENT
This section details the use, limitations and system checks for a wide range of DP components and equipment, including differential GNSS, FANBEAM and CyScan systems, Artemis, taut wire, RADius and RadaScan systems, HPR and HAIN systems, gyrocompass, motion reference unit/vertical reference unit, wind sensors and thrusters.
TRIALS, TESTS AND FAILURES
This section looks at the trials and checks that are required to ensure compliance with standards and guidelines. It describes processes for identifying critical single point failures, so that they can be eliminated or minimised at an early stage. It also describes common failures and emergencies, using case studies to illustrate how they may be avoided.
ROLES OF DP VESSELS
This section explains the principles and procedures of dynamic positioning in a number of applications, including diving, offshore drilling, ROV support, pipe and cable lay, anchor handling, heavy lifts, FPSOs, shuttle tankers, dredging and rock dumping. It identifies critical stages in these operations together with the applicable DP functions.
Shukla K.C. Dynamic Positioning Theory & Practices, 2018.pdf
Dynamic Positioning Systems: Class Guidance for DP Operators - Fidaa Karkori [2024, PDF]
Guide to Meteorological Instruments and Methods of Observation (CIMO guide) - WMO [2014, PDF]
Guide for Dynamic Positioning Systems - American Bureau of Shipping (ABS) [2024, PDF]
Guide for Dynamic Positioning System - ABS [2021, PDF]
Dry Docking and Shipboard Maintenance - A Guide for Industry - David House [2016, PDF]
ABS - Guide for Dynamic Positioning Systems - ABS [2021, PDF]
ECDIS and Positioning (Integrated Bridge Systems) - Andy Norris [2016, PDF]
The Yacht Navigator’s Handbook - Normahn Dahl [1983, PDF]
Guide to Dynamic Positioning Systems - American Bureau of Shipping [2014, PDF]
Hydraulic Structures - C. S. James [2020, PDF]
The time now is: Today 23:01
