5sb1 ®   09-Mar-2023 16:47
USS MISSOURI BB63 PLAN BOOK
Year: 2006
Author: Thomas F. Walkowiak
Genre: Other
Publisher: The Floating Drydock
Pages count: 303
Description: This book is divided in sections, each giving the details of all exterior parts of that area. We started off with the bow and worked aft to the
end of the superstructure. We then work our way up the decks of the superstructure and masts. After all these details are covered we go
thru the after main deck area starting at about Fr. (Frame) 53 and work aft to the stern of the ship. We then go into detail of the guns, from
the 20mm to the 16” triple turret.
After the weapons section, we cover the ships spotter aircraft and the ships camouflage painting. We also cover the ships numbers,
propellers, hull form and various details.
All main deck drawings were drawn in 1:48 scale and reduced to 1:96 scale for this eBook. Various detailed equipment drawings and
illustrations are in different scales, where possible dimensions are given.
Printing: All deck drawings SHOULD print out in 1/96 scale, either in "portrait or landscape".
BB63 MISSOURI.pdf
Download [17 KB]
The Japanses Destroyer Akizuki (TopDrawings 7038) - Koszela W. [2016, JPEG]
Skoryi class Destroyer (TopDrawings 7082) - Koszela W. [2018, JPEG]
Τhe Battleship USS Massachusetts (TopDrawings 7046) - Koszela W. [2017, PDF]
Victotia-class Battleship HMS Victoria (1887) - Paper Model - CarlP. Beetz [2009, JPEG]
USS Iowa (BB 61) (Warship’s Data 3) - Robert F. Sumrall (Editor) [1986, PDF]
Ship Stability : MV Almar Stability Data Book - Martin, Rhodes [2012, PDF]
Deco for Divers - A Diver’s Guide to Decompression Theory and Physiology - Powell M. [2013, MOBI]
Iowa-Class Battleships - David Doyle [2017, PDF]
The Adlard Coles Book of Mediterranean Cruising - Rod Heikell [2012, PDF]
Shipbuilding (Gemi İmalatı) - Ahmet Tokgöz, Atilla Yurdagül [2020, PDF]
The time now is: Today 11:48
