twicer ®   22-Feb-2023 12:36
Safety Flash - February, 2023
Year: 2023
Author: IMCA
Pages count: 6
Description: Safety Flash issue no. 04/23 – February, 2023
The International Marine Contractors Association ( IMCA ) Safety Flashes disseminate important information on incidents and potential hazards and the lessons learnt from them that can help prevent incidents occurring elsewhere in the industry.IMCA Safety Flashes and systems for incident reporting and analysis are an important tool for sharing vital information.By publishing them, IMCA helps its members around the world identify potential hazards, share lessons learned and avoid repetition.Safety Flashes should be succinct, specific, factually correct and written in clear language.The Secretariat will assist with this through formatting and checking of the material submitted.
IMCA SF 04/23
• High potential near miss: Uncontrollable movement of auxiliary whip line
• Uncertified lifting gear found in use
• Dropped objects in dry dock
• Air hose connection failure
• Electrolytic corrosion: failure of fire hose couplings
SF-04-23.pdf
Download [1 KB]
Safety Flash issue 11/23 (May) - IMCA [2023, PDF]
Safety Flash issue 06 (March) - IMCA [2023, PDF]
Safety Flashes issues 07-10 (March - April) - IMCA [2023, PDF]
Safety Flashes issues 01-32 - IMCA [2021, PDF]
Safety Flashes issues 20-24 (August-October) - IMCA [2023, PDF]
Safety Flash issues 24-26/22 - IMCA [2022, PDF]
Safety Flash issue 16/22 - IMCA [2022, PDF]
Safety Flash issue 02 (January) - IMCA [2023, PDF]
Safety Flash issue 15 (June) - IMCA [2023, PDF]
Safety Flash issue 02 (January) - IMCA [2024, PDF]
The time now is: Today 17:55
