skipper3362 ®   19-Feb-2023 16:04
Walkaround Inspection For Diesel Generators
Year: 2022
Playtime: 34 min
Quality: WEB-DL
Format: MP4
Video: H.264 1280x720 30 fps
Audio: AAC 48.0 KHz x 320 Kbps
Description: Walkaround Inspection for Diesel Generators
What you'll learn
Understand the importance and benefits of conducting a walk around inspection.
Understand the step by step process of conducting walk around inspection.
Learn how to document the inspection for your future reference
Learn Main components and its functions of Diesel Generator
Requirements
No Prerequisites
Description
Diesel Generators are most known as stand by power source. But generator must be inspected and keep up to date on daily basis to supply the power at any general power supply interruption. There are key factors that need attention on such daily inspection.There are several benefits that you earn when you perform the walkaround inspection on daily basis. They could be list as follows:1. Prevent Sudden Breakdowns of your site / organization2. Increase the availability of your Power Generator to power up in any emergency.3. Reduce Down Time of the generator so that no disturbance in the daily operation..4. Plan and schedule Maintenance Work can be well panned to avoid sudden power interruption issuesAbove benefits will eventually lead to the cost reductions for your generator repair and it shall increase the profitability of your organization.This program would give you the knowledge on how to perform Visual Walk Around Inspection on Diesel Generator safely, efficiently, and effectively towards more proactive equipment management.This programmed consists of ten short modules where each module will focus on as specific component or section of the generator. We recommend you to follow this course and get the maximum benefits. This is a begginer levelk course; hence it is explained at basic level so that any fresh graduate also can understand the concepts and procedures explained in the programmed .
Overview
Lecture 1 Introduction
Section 1: Cooling System,
Lecture 2 Cooling System & Radiator
Section 2: Lubrication System
Lecture 3 Lubrication System
Section 3: Lubrication System Components
Lecture 4 Lubrication System Components
Section 4: Charging Alternator
Lecture 5 Charging Alternator
Section 5: Air Inlet and Exhaust System, Jacket Water After Cooler
Lecture 6 Air Inlet and Exhaust System, Jacket Water After Cooler
Section 6: Oil Sump (Crank Case)
Lecture 7 Oil Sump (Crank Case)
Section 7: Fly Wheel End
Lecture 8 Fly Wheel End
Section 8: Separate Circuit After Cooler Pump, Engine Breathers
Lecture 9 Separate Circuit After Cooler Pump, Engine Breathers
Section 9: Starting System
Lecture 10 Starting System
Section 10: Control Panel
Lecture 11 Control Panel
Section 11: Component Identification
Lecture 12 Component Identification
Machine Operators, Beginner Level Technicians, Anyone interested in heavy machinery, Fleet Managers, undergraduates looking to start work.
Download [15 KB]
Forklift Walkaround Inspection [2022, MP4]
Introduction to Diesel Generator System (DG Set) [2022, MP4]
Hydraulic Systems: A Complete Guide to Hydraulics knowledge [2021, MP4]
Shielded Metal Arc Welding [2022, MP4]
Mentoring Masterclass: Complete Guide For Mentors & Mentees [2020, MP4]
Nebosh-igc, Element-1, Health and Safety Foundation. [2021, MP4]
Risk Management [2023, MP4]
Osha Safety Pro: Personal Protective Equipment [2017, MP4]
Crane And Hoist Safety [2022, MP4]
Osha Safety Training: Conducting Safety Meetings [2020, MP4]
The time now is: Today 14:40
