abdallahwsm ®   25-Jan-2023 06:13
Cargo Handling System - Membrane Type LNG Carrier Operations Training
Year: 2005
Author: Gaztransport &Technigaz
Genre: Training courses
Pages count: 95
Description: Two common membrane tank designs are those developed and associated with the French companies Gaz Transport and Technigaz. The Gaz Transport system uses a 36% nickel–iron alloy called ‘Invar’ for both the primary and secondary barriers. Invar has a very low coefficient of thermal expansion, which makes any corrugations in the tank structure unnecessary. The Invar sheet membrane used is only 0.5–0.7 mm thick, which makes for a very light structure. Insulation consists of plywood boxes filled with perlite.
The Technigaz system utilizes a stainless-steel membrane system where tanks are constructed of corrugated sheet in such a way that each sheet is free to contract and expand independently of the adjacent sheet. This forms the inner primary barrier and a balsa insulation and secondary barrier similar to that fitted to the Independent Type A tanks is fitted.
LNG_CARGO_HANDLING_SYSTEM___95.pdf
Download [15 KB]
LNGC Catalunya Spirit - IMO 9236420 - Machinery Systems Operating Manual - WMT [2003, PDF]
Training on Membrane LNG techniques - Gaztransport &Technigaz [2005, PDF]
NYK - LPG Stars (Shipboard Training and Assessment Recording System) - NYK [2006, PDF+MP3]
Types of Ships - 3D Animation [2022, MP4]
Model Course 1.35 Liquefied Gas (LPG) Tanker Cargo and Ballast Handling Simulator, 2007 Edition - IM...
A Practical Guide to Bulk Carrier Inspection - Capt. Dario Petkovic, dipl. Ing. MNI [2023, PDF]
5000 M3 LPG VCM Cargo System Operation Manual - Sanoyas Hishino Meisho Co [2001, PDF]
Ship Handling Notes - Capt. S.F. Gomez [2020, PDF]
Hydraulic CALC pro v.1.60 - Hydro Works Interactive [2018] [Android]
AWS-D1.2-2014-structural-welding-code-aluminum - AWS [2014, PDF]
The time now is: Today 05:31
