skipper3362 ®   16-Sep-2022 19:13
EIVA NaviCat
Year: 2022
Version: 4.5.2
Developer: EIVA
64-bit OS compatibility: yes
System Requirements: Windows 10
Crack: Included
Description: NaviCat is a software option within the NaviSuite Beka solution. NaviSuite Beka is a versatile, scalable and user-friendly software solution that increases the efficiency and safety of anchor handling operations during rig move and barge management projects.
The solution combines anchor handling and catenary data acquisition, ROV inspection, and reporting in a single tool that covers both operation planning and execution. This simplifies the work process and reduces the risk of calculation errors that comes with using multiple software tools.
The illustration below shows how NaviCat integrates with other parts of the NaviSuite Beka solution.
Highlights
· Precise positioning through interfacing with NaviPac
· Cable laying through interaction with CableLay
· Advanced 3D display through interfacing with NaviPac or HMD4
· Support for NaviModel DTMs
· And much more...
keymaker can resulte in warnings from antivirus programs
This post 13 of 13 posts
is posted as i found it
Additional info: HOW TO iNSTALL
1. Install the program and run the app to obtain your PC Code
from the license activator or about screen. Close the app
2. Use our keyfilemaker to generate a soft dongle license for
your PC Code. It will automatically put the license in the
correct place
3. Enjoy!
NOTE: While our keyfilemaker will automatically obtain your PC
code (hardware ID), you can change this to generate
licenses for other machines.
In this case, your license will be placed on the desktop
with instructions where to place it on the other machine
EIVA NAVCAT
Download [17 KB]
spbx   23-Oct-2022 18:18
Ключ генератор отсутствует в архиве, просьба исправить.
EIVA UCA v.4.5.3 - EIVA [2022]
EIVA NaviPac v.4.14.1 - EIVA [2026]
Loadstar v.1.0 - IBM [2008]
EIVA QC Toolbox v.4.6.1 - EIVA [2022]
EIVA Kuda Core v.4.8.0 - EIVA [2025]
EIVA Workflow Manager v.4.6.0.4 - EIVA [2022]
CargoMax for Livestock Carriers Demo v.2.1 - Herbert-ABS [2020]
WinCASP ships profiles - CASP [2001]
CargoMax for Bulk Carriers Demo v.2.1 - Herbert-ABS [2020]
Spectec - AMOS2 End User Training Guide - M.Youngson [2010, PDF]
The time now is: Today 13:04
