skipper3362 ®   10-Apr-2022 21:24
HYPACK 2022
Year: 2022
Version: v1.22
Developer: Hypack
64-bit OS compatibility: yes
System Requirements: windows 10 x64
Crack: Included
Description: HYPACK - A Xylem Brand and now part of YSI is a Windows based software for the Hydrographic and Dredging Industry. Founded in 1984, HYPACK, INC (formerly Coastal Oceanographics, Inc.) has evolved from a small hydrographic consultant to one of the most successful providers of hydrographic and navigation software worldwide. HYPACK is one of the most widely used hydrographic surveying packages in the world, with more than 10,000 users.
It provides the Surveyor with all the tools needed to design their survey, collect data, process it, reduce it, and generate final products. Whether you are collecting hydrographic survey data or environmental data, or just positioning your vessel in an engineering project, HYPACK provides the tools needed to complete your job. With users spanning the range from small vessel with just a GPS and single beam echosounder to large survey ships with networked sensors and systems, HYPACK gives you the power needed to complete your task in a system your surveyors can master.
HYPACK hydrographic survey software solutions provide customers with data collection and processing that enable real time imaging, terrain modeling, and statistical reporting. HYPACK solution and display features include
Data collection and processing: Single beam, multibeam, side scan sonar, etc.
Real-time imaging, targeting, QC, graphical/automated editing.
Navigational and dredging support with digging efficiency and precise positioning.
Reports for sections, volumes, TIN models, plots, side scan mosaic, performance, and data statistics.
hypack 2022 , v.1.22
Download [18 KB]
Guest   27-Nov-2022 15:04
hello
thanks for that because it is really helpful for me to collect bathymetric data and processed.
nvc   22-Jan-2023 14:19
Конкретно это лекарсво не делает HP рабочим не работает съемка
Есть другой способ активации описанный на лавтим вместе с обновлением Q2
nvc   31-Jan-2023 13:23
skipper3362,
What you posted here is posted in the original source on the forum loveteam. This license no longer works, i.e. the main functionality of the Survey module reports an illegal copy when working with connected equipment. There is a keygen that activates everything as expected. Also already have HP2023
bk10   10-Apr-2023 16:02
nvc, hello, is it possible for you to share a new link? i need hypack
Guest   28-Apr-2023 04:47
skipper3362, This didn't work. I see the soft license. It is still in demo mode, however. I Had to create the C:\ProgramData\Hypack\ folder (hypack wasnt there). any ideas?
Thanks.
Guest   28-Apr-2023 06:45
skipper3362, i figured it out. the library file needs to be put in the x64 folder under hypack then it works. thanks for providing this.
Yenyi   14-May-2023 09:21
skipper3362, can this run cross section and volume? I have 2021 version but I can't run cross section
valerygen65   12-Jul-2023 17:46
skipper3362, Добрый день. А вот у меня программа устанавливается на диск С. В program data даже папки нет.
И как понять первую - <instaldir> где это находится?
Offshore Surveying - All To Starting [2024, MP4]
EIVA QC Toolbox v.4.6.1 - EIVA [2022]
The Geometry of Ships - John Letcher, J. Randolph Paulling [2009, PDF]
Sodena Turbowin 8.0.25 + C-MAPv3 SDK v5.2 v.8.0.25 - Echomaster Marine Ltd. [2018]
Aerographer’s Mate Module 4-Environmental Communications and Administration - US Navy [1999, PDF]
C0Mputational Techniques For Tidal Datums Handbook; NOAA Special Publication NOS CO-OPS 2 - Michael ...
What A Marine Surveyor Needs To Know About DYNAMICALLY POSITIONED VESSELS - Hugh Raynor - Internatio...
EIVA Workflow Manager v.4.6.0.4 - EIVA [2022]
Smart Vessel - DNV [2021, PDF]
The time now is: Today 11:55
