gillnumil ®   17-Mar-2022 08:18
Climate Change
Year: 2021
Author: Reeta Pal
Format: EPUB
Pages count: 33
Description: Scientists can conclude that the global average temperature is rising by using a variety of measurements taken over decades on land, in the sea, and in air. High confidence is given to the conclusion that the global climate is altering based on observational data for many other climate variables. The temperature in the ocean and lower atmosphere has increased as well as near-surface humidity, and sea level. The ocean has seen an increase in heat content, and more than 90% of energy from the ocean-atmosphere combination over the past decade has gone into the ocean. Five observational datasets indicate that the ocean's heat content is rising.
Chapter 1: Globally Changing Climate
Chapter 2: Physical Drivers of Climate Change
Chapter 3: Detection and Attribution of Climate Change
Chapter 4: Large-Scale Circulation, Climate Variability
Chapter 5: Droughts, Floods, Storms and Wildfires
Chapter 6: Land Cover Changes and Terrestrial Biogeochemistry
Chapter 7: Perspectives on Climate Change Mitigation
Climate Change (109).zip
Download [639 B]
Hurricanes - Michael Allaby [2003, PDF]
Physics of the marine atmosphere - van Mieghem J. (Eds.) [1965, DjVu]
Annotated Atlas of Coastal and Marine Winds - Nazla Bushra, Robert Rohli [2021, PDF]
Global Satellite Meteorological Observation (GSMO) - Applications, Volume 2 - Stojče Dimov Ilčev [20...
Ocean Circulation and Climate: Observing and Modelling the Global Ocean - Gerold Siedler, John A. Ch...
Can Coastal Cities Turn the Tide on Rising Flood Risk? - McKinsey Global Institute [2020, PDF]
Descriptive Physical Oceanography - Talley & Pickard & Emery & Swift [2011, PDF]
Operating and Maintenance Instructions, Intrinsically Safe Triple Function Gauging Tape for Open App...
The Blue Book Copernicus For A Sustainable Ocean - HSH Prince Albert II of Monaco et alli [2019, PDF...
Seasonal to Decadal Predictions of Arctic Sea Ice: Challenges and Strategies - Polar Research Board,...
The time now is: Today 23:09
