grv.techy ®   05-Dec-2021 22:30
Yanmar 4LHA Marine Engine Manuals
Year: 2017
Author: YANMAR Diesel Engine Co. Ltd Japan
Pages count: 466
Description: Yanmar Marine Diesel Engine 4LHA- Variants Operation and Maintenance Manual in different PDFs.
Specifications
Rated Output - 177 kW / 240 mhp
Rated Speed - 3300 rpm
Displacement - 3.455 L / 211 cu. in
No. of cylinders - 4 cylinders
Cylinder Bore x Stroke - 100 mm x 110 mm / 3.94 in x 4.33 in
Combustion system -Direct Injection, In-line Pump
Aspiration - Turbocharged & Intercooled
Alternator - 12V - 80A
Dry weight without gear - 365 kg / 805 lbs
Dimensions - 1131 mm x 719 mm x 811 mm
Controls - Mechanical
Yanmar
Download [9 KB]
MaK M 25 C Project Guide & Propulsion - Caterpillar Motoren GmbH & Co. KG [2008, PDF]
YANMAR Diesel Generators: M6EY18AL-ALV, M6N21L-V, M6N165L, M6NY16L (manuals + video) - maintenance a...
MAN B&W Low Speed Small Bore Engines Now with Electronic Control - MAN [2014, PDF]
NMC 52: Electronically Controlled Engine (MAN B&W ME) Training Textbook - NYK Maritime College [2012...
Robust Control of Diesel Ship Propulsion - Nikolaos Xiros, Dr-Eng [2002, PDF]
Introduction to Diesel Generator System (DG Set) [2022, MP4]
Auxiliary Engines [2017, MP4]
Marine diesel engines: Maintenance, Troubleshooting, and Repair - Nigel Calder [2007, PDF]
Marine Engine Programme - MAN [2022, PDF]
Marine Engine Programme - MAN Energy Solutions [2024, PDF]
The time now is: Today 19:21
