pierdolphin1950 ®   14-Nov-2021 09:54
IPIECA - IOGP - Guide to shoreline clean-up techniques
Year: 2015
Author: IPIECA - IOGP
Pages count: 68
Description: This Good Practice Guide is divided into four sections. The first section sets out ten important factors to be considered when contemplating the clean-up of an oiled shoreline. In Section 2, the steps to be taken in managing shoreline clean-up operations are discussed. The third section describes some of the most frequently used clean-up techniques, and sets out the advantages and limitations of each one, as well as the stages in the overall operation when a particular technique is likely to be most useful. The fourth section examines the interaction between stranded oil and different shoreline types, and suggests some possible approaches to addressing the challenges that this interaction can present.
IPIECA - IOGP - Guide to shoreline clean-up techniques.pdf
Download [7 KB]
IPIECA - IOGP - A guide to oiled shoreline assessment (SCAT) surveys - IPIECA - IOGP [2014, PDF]
IPIECA - IOGP - Key principles for the protection care and rehabilitation of oiled wildlife - 2017 -...
IPIECA - IOGP - Wildlife response preparedness - IPIECA - IOGP [2014, PDF]
IPIECA - IOGP - Dispersants subsea application - 2015 - IPIECA - IOGP [2015, PDF]
IPIECA - IOGP - Dispersants surface application - 2015 - IPIECA - IOGP [2015, PDF]
IPIECA - IOGP -Impacts of oil spills on shorelines - IPIECA - IOGP [2016, PDF]
IPIECA - IOGP -Oil spill waste minimization and management - IPIECA - IOGP [2014, PDF]
POSOW - Oiled Shoreline Assessment Manual - POSOW [2013, PDF]
Daymarks for Aids to Navigation, Edition 2.0 - IALA [2016, PDF]
IPIECA - IOGP - Oil spill monitoring and sampling - IPIECA - IOGP [2020, PDF]
The time now is: Today 07:08
