twicer ®   05-Nov-2021 13:27
Calculation of Crankshafts for Reciprocating internal Combustion Engines
Year: 2021
Author: DNV
Genre: Class Guideline
Pages count: 76
Description: This class guideline contains an alternative method to the method given in IACS UR M53 for calculation of
safety against fatigue failure in pin and journal fillets and in oil bores.
In principle, any relevant calculation method may be applied, e.g. the fatigue criteria assume that maximum
respectively minimum bending stresses occur simultaneously with the maximum respectively minimum
torsional stresses.
If properly documented, an evaluation of the fatigue capacity by using multi-axial fatigue methods may
replace the criteria applied in this class guideline.
A crankshaft will be approved when the calculation methods, as presented in this class guideline, is fulfilled.
Crankshafts that cannot satisfy these rules may be subject to special consideration when detailed calculations
and/or measurements are made to demonstrate equivalence to these rules.
DNV Guideline_Calculation of crankshafts for reciprocating internal combustion engines.pdf
Additive manufacturing - Qualification and Certification process for Materials and Components - DNV…
Wave loads - DNV GL [2018, PDF]
Foundation and Mounting of Machinery - DNV [2021, PDF]
Fatigue assessment of stern ramps - ARON JALKEVIK AND KARL TORESSON [2013, PDF]
Determination of structural capacity by non-linear finite element analysis methods DNVGL-RP-C208 -…
Guideline for Cyber Secure - DNV [2021, PDF]
Engineering fundamentals of the internal combustion engine - Willard W. Pulkrabek [2003, PDF]
Service experience for Everllence B&W ME-LGIP engines - Everllence [2025, PDF]
Torsional Vibration Calculation
The time now is: Today 11:38
