zxc ®   03-Aug-2012 21:49
ГМССБ Симулятор (Фуруно) / Furuno – GMDSS Simulator
Year: 1996
Version: 1.0.0.1
Platform: PC
Crack: Not needed
Description:
OPERATION PROCEDURES KANNAD 406 FH-FLOAT FREE TYPE
Operating principle
This container is used to protect an EPIRB (Emergency Position Indicating Radio Beacon) of the KANNAD 406 type and to ensure that it is released and that it operates automatically in the event of a boat sinking. It should be installed on the wheelhouse horizontally, so that the beacon can rise easily to the surface.
The CAL 89 [1] makes an envelope that gives excellent protection to the beacon. This envelope is made of IMPAX, a polycarbonate material extremely resistant to shocks, according to the double skin technique filled with polyurethane foam. The release device used is the Hammar H20 hydrostatic release.
At a depth of 4 to 12ft, the release system operates and cuts the bolt. The top cover is freed and allows the beacon to rise to the surface [3] : when the beacon leaves the bottom part of the container, it is automatically in "on" position. It is absolutely necessary to follow scrupulously the installation and operation instructions. It is possible to open the container manually by removing the release pin
Weight of container - 4,5 kg or 9 lb. (Epirb and container).
Size - 435*220*160mm.
More...
Beacon insertion
1. The container is fixed to the wheelhouse (see installation instructions).
2. Place beacon in container according to position indicated. The operating switch is placed underneath.
3. To arm beacon, raise beacon slightly, unscrew plastic cap, switch beacon to "on". Screw plastic cap back on. Put beacon back into place.
WARNING : Do not exceed 30 secs to avoid any real distress transmission.
4. To ensure that the beacon is working, raise it slightly and check that the lamp flashes after a few seconds. Put it back. The switch remains in position "on".
5. While maintaining the beacon inside the container, put the hinges into place and close the lid .
6. Slide the release pin through the axle to lock the container .
Operating principle
Beacon insertion
Furuno.rar
Navtex   09-Sep-2012 08:37
Из всех доступных тренажеров GMDSS этот, пожалуй, не самый удачный. Да, несомненно, он дает представление о принципах работы с аппаратурой, но провести полноценную тренировку на нем сложно. Там доступны лишь основные функции. Хотя, если нет доступа к реальной аппаратуре, а есть только инструкция пользователя и надо срочно освоить комплекс - симулятор окажется очень кстати.
zxc ®   09-Sep-2012 12:33
А есть удачные тренажеры на примете?
Navtex   11-Sep-2012 13:18
Да, есть. Например, GMDSS Tutor "Sailor" - дает возможность попробовать большинство из возможных функций. Есть выход на справку, где объясняется как пользоваться симулятором и приборами. У меня есть эта программа, но не помню откуда скачал - она у меня уже несколько лет. Еще одна учебная программа - Maritime Communications. Там целый теоретико-практический курс на английском языке. В конце курса что-то типа ролевых игр. Вы на мостике на вахте, что-то случается и капитан приказывает вам как можно быстрее отправить сигнал бедствия, время лимитировано. Короче - отличная учебная программа для новичков. Я найду ссылки и выложу их на сайте.
Navtex   17-Sep-2012 09:07
Могу еще порекомендовать очень хороший on-line симулятор.
http://www.egmdss.com/gmdss-courses/
На этом сайте можно либо сразу выйти на симулятор и попробовать освоить аппаратуру самостоятельно (либо освежить в памяти знания), а можно предварительно пройти курс обучения на английском языке. Симулятор и курс хорошие, они как бы дополняют сведения, полученные в результате работы с тремя предыдущими.
Для начинающих могу посоветовать начать либо с этого курса, либо с Maritime Communications, потом расширить полученные знания, занимаясь на GMDSS Tutor "Sailor", и только после этого можно приступать к ознакомлению с Furuno – GMDSS Simulator.
zxc ®   17-Sep-2012 23:34
Может займетесь разделом Симуляторы?
Navtex   27-Sep-2012 18:00
Да, симуляторов у меня много - хобби такое. Только вот с торрентами я не в особо дружеских отношениях - мой компьютер их не любит. Для меня лично удобнее пройтись по ссылке и скачать из файлообменника.
zxc ®   27-Sep-2012 18:09
Я могу разжевать что да как Улыбка Минус файлообменников в том что ссылки мрут как мухи и приходится перезаливать
Navtex   28-Sep-2012 08:50
Тоже правильно. Ну, ничто не вечно под Луной. Мигает Тут уж каждый выбирает кому как удобнее.
Видеоуроки по ГМССБ - MorskoyKlub [MP4]
Marine Online - Liferaft Launching Procedure [2018, MP4]
Thrane & Thrane - Sailor system HC4500 MF/HF Control Unit Operating Instructions - Thrane & Thrane…
Fixed Fire Fighting Systems and Emergency Procedures (For Ship’s Engine Room) - MD MAHBUBUR RAHMAN…
Questions and Answers for Marine Engineers - Viktor Knyazyev [2014, PDF]
Thrane & Thrane - Sailor System 5000 MF/HF 150/250/500W - Thrane & Thrane A/S [2010, PDF]
Hammar H20 - How it works [2020, AVI]
SAM System 5000 MF/HF 150W/250W/500W Control Unit SAM CU5100 - Sam Electronics [2008, PDF]
GMDSS VHF DSC Simulator v.1.3.4 - dscsim & ochecker [2008]
The time now is: Today 15:00
