perkolllll ®   26-Aug-2021 23:37
Nobeltec InSight Radar 2 (IR2) - Radar Operations Manual
Year: 20xx
Author: Nobeltec
Pages count: 67
Description: InSight Radar (or IR2) is Nobeltec’s comprehensive radar solution. It includes either a special radar that transmits digital data or a converter box to convert the standard analog radar into the required digital format. It also includes a special version of Nobeltec’s navigation software designed to work with this digital radar data stream.
This radar software includes a host of powerful tools designed to make navigating more safe and fun.
If the InSight Radar option is installed on top of the Nobeltec Visual Navigation Suite or Admiral programs, the version of the program is followed by an “R” (e.g. Version 7.0.793R) and will say InSight Radar on the Help | About screens. You will also see a Radar drop down menu near the other menu options.
This manual assumes that you are already familiar with Nobeltec’s charting software. The Nobeltec software is easy-to-use and powerful. If you need a brush-up, please refer to the Users Guide that came with your Nobeltec charting software.
You can also access the On-line Software Help File by clicking on the Help drop down menu and then on the Help Topics option.
InSight Radar Introduction ...........................1
Welcome to Nobeltec ..................................1
What is Nobeltec’s IR2? ..............................1
The InSight Radar Window .............................2
What is a Nobeltec digital radar? ....................4
How Does the Nobeltec Digital Radar Work? ............4
Important Notice Regarding 2kW Dome Models ...........4
What is the InSight Radar Box? .......................5
How Does the InSight Radar Box Work? .................5
Minimum System Requirements ..........................6
Recommended System Requirements ......................6
Setting up InSight Radar .............................7
Installing InSight Radar (IR2) .......................7
Installing the Hardware ..............................7
Installing Nobeltec Software .........................8
Using the Radar Setup Wizard .........................9
Initial Radar Setup ..................................12
Setting the Trigger Delay ............................12
Aligning the Radar Image .............................13
Setting the Radar Presets ............................17
Working with InSight Radar ...........................21
Opening the InSight Radar Window .....................21
Turning on your Radar ...............................22
Radar right click and Radar menu .....................22
Radar Toolbars .......................................23
Range Scale ..........................................24
Adjusting the Gain ...................................26
Reducing Sea Clutter (SEA) ...........................26
Reducing Precipitation Clutter (Rain) ................27
Radar / Chart Overlay ................................28
Cursor Ghosting ......................................29
Rejecting Radar Interference .........................29
Measuring the Range and Bearing to a Target ..........30
Setting up a Guard Zone ..............................32
Pulse Length .........................................32
Radar Orientation (rotation) .........................33
Off Centering the radar (shifting) ...................34
Recording the Radar .................................35
Decluttering the Radar ...............................36
Resizing the Radar Image .............................37
Using Radar in Admiral - Advanced Features ...........38
NavView’s Multiple Monitor Support ...................38
Full Screen Radar Console ............................39
NavView Toolbars .....................................41
Target Tracking ......................................42
Point and Click Radar (MARPA) ........................43
Radar Configuration Options ..........................47
Understanding Radar ..................................51
How to Interpret the Radar Picture ...................51
Radar Horizon ........................................53
Radar Horizon and Mother Nature ......................53
Minimum Detectable Range .............................54
Troubleshooting ......................................57
Troubleshooting Direct Connections ...................57
Troubleshooting Network Connections ..................58
Frequently Asked Questions ...........................61
Radar_Op_Man.pdf
JRC Marine Radar Instruction Manual JMA-5300 Series - JRC [2013, PDF]
JRC Marine Radar Instruction Manual JMA-5200 Series - JRC [2010, PDF]
Maris ECDIS900 Operator Manual - Navico Holding AS [2017, PDF]
JRC Marine Radar Instruction Manual JMA-900B RADAR Mode - JRC [2012, PDF]
JRC Marine Radar Instruction Manual JMA-91XX Series - JRC [2011, PDF]
JRC Marine Radar Instruction Manual JMA-9172-SA - JRC [2011, PDF]
Ship Radar CRT Simulator (Radar Trainer) v.4.0102 - LightMaster [2000]
JRC JAN-701B/JAN-901B (Instruction Manual) - Japan Radio Company [2012, PDF]
JRC Marine Radar Instruction Manual JMA-3300 Series - JRC [2011, PDF]
Transas ECDIS Demo 2.0 v.2.00.015 - Transas [2010]
The time now is: Today 14:16
