Ferreirolo ®   23-Jul-2021 18:17
Fundamentos de los sistemas de radionavegación
Year: 201?
Language: spanish
Author: José López Vicario
Genre: Textbook
Publisher: UOC
Pages count: 80
Description: Radio navigation systems are positioning systems that estimate the position of a target or user terminal using radio signals. These systems began to be developed at the beginning of the 20th century and are still very useful in many applications. These systems are classified into terrestrial radionavigation systems and satellite radionavigation systems, depending on whether ground stations are used to send / receive radio signals, as in the first case, or whether satellite constellations are used, as in the second case.
Radio navigation systems are introduced in this module. First, however, the most commonly used coordinate systems and projection systems in radionavigation are described. Once this is done, the best-known terrestrial radio navigation systems are described, classifying them into two groups according to their operating principle: radio beacons and hyperbolic systems. Subsequently, another type of systems used in airports is introduced to manage the approach control of the aircraft to them and to provide assistance to the pilots in landing tasks. Finally, the module concludes by presenting the satellite radionavigation systems. Specifically, a general description of the most important satellite radionavigation systems is provided, also introducing their basic concepts and some notions of orbital mechanics.
Los sistemas de radionavegación son sistemas de posicionamiento que estiman la posición de un blanco o terminal de usuario utilizando señales radio. Estos sistemas empezaron a desarrollarse al inicio del siglo XX y siguen siendo aún de gran utilidad en multitud de aplicaciones. Estos sistemas se clasifican en sistemas de radionavegación terrestres y sistemas de radionavegación por satélite, dependiendo de si se usan estaciones terrestres para enviar/recibir las señales radio, como en el primer caso, o si se recurre a constelaciones de saté- lites, como en el segundo caso.
En este módulo se presentan los sistemas de radionavegación. En primer lu- gar, no obstante, se describen los sistemas de coordenadas y los sistemas de proyección más utilizados en radionavegación. Hecho esto, se pasa a describir los sistemas de radionavegación terrestres más conocidos, clasificándolos en dos grupos según su principio de funcionamiento: los radiofaros y los siste- mas hiperbólicos. Seguidamente, se introduce otro tipo de sistemas utilizados en aeropuertos para gestionar el control de aproximación de las aeronaves a los mismos y para proporcionar ayuda a los pilotos en las tareas de aterriza- je. Finalmente, el módulo concluye presentando los sistemas de radionavega- ción por satélite. Concretamente se proporciona una descripción general de los sistemas de radionavegación por satélite más importantes, introduciendo además los conceptos básicos de los mismos y algunas nociones de mecánica orbital.
Sistemas de radionavegación_Módulo 3_Fundamentos de los sistemas de radionavegación.pdf
Download [1 KB]
Global Mobile Satellite Communications Theory For Maritime, Land and Aeronautical Applications, 2nd ...
Engineering Satellite-Based Navigation and Timing - John W. Betz [2015, PDF]
US Federal Radionavigation Plan, 2019 - US Department of Homeland Security and Department of Transpo...
Admiralty List of Radio Signals Volume 2 - U.K. Hydrographic Office [2009, PDF]
Availability of Maritime Radio Beacon Signals for R-Mode in the Southern Baltic Sea - S. Gewies, L. ...
Principles of GNSS, Inertial, and Multisensor Integrated Navigation Systems - Paul D. Groves [2008, ...
Radar and Electronic Navigation - G. J. Sonnenberg [1988, PDF]
Marine Navigation and Safety of Sea Transportation - Info, Communication & Environment - A.Weintrit ...
Tropospheric and Ionospheric Effects on Global Navigation Satellite Systems - TImothy H. Kindervatte...
Modern Inertial and Satellite Navigation Systems - Allonzo Kelly [1994, PDF]
The time now is: Today 10:59
