Did you find useful?
yes
0% [ 0 ]
nope
0% [ 0 ]
Total Votes : 0
mertix57 ®   29-Mar-2021 12:45
Isle of Man Ship Registry - SOLAS II-2 The Maintenance and inspection of fire protection systems and appliances
Year: 2016
Author: Isle of Man Ship Registry
Publisher: Isle of Man Ship Registry
Edition: 2016
Quality: OCR without errors
Pages count: 14
Description: Introduction
This Notice sets out the minimum level of maintenance and inspection for fire protection systems and appliances onboard Isle of Man registered ships. This information may be used as the basis for the ship’s onboard maintenance plan required by SOLAS regulation II-2/14.
This Notice has been developed taking into account various guidelines published by the International Maritime Organisation which are intended to ensure that fire systems are kept in good working order as specified in SOLAS Regulation II-2/14.2.1.2. These guidelines should be followed, although where particular arrangements create practical difficulties approval must be sought from the Ship Registry for an alternative testing and maintenance procedures. These guidelines do not preclude the shipowner from demonstrating an equivalent or higher standard as an “alternative method” of compliance.
For ease of reference a testing and inspection schedule has been set out in Appendix 1 of this Notice.
msn-057-solas-ii-2-maintenance-and-inspection-of-fire-protection-systems-and-appliances.pdf
Download [746 B]
On board Maintenance and Drills agenda (updated) - Dromon [2022, PDF]
On board Maintenance and Drills agenda - DBS [2020, PDF]
Master’s Handbook - Isle of Man Ship Registry [2021, PDF]
Pilot transfer arrangements - AMSA [2023, PDF]
Recovery of persons from the water - Guidelines for the development of plans and procedures - IMO + ...
Good Maintenance Onboard Ships - ClassNK [2017, PDF]
MSN (F)1882, 1884, 1885,1891 – ILO work in fishing convention minimum age, working time, survey and ...
Code on Noise Levels on Board Ships with Guide for Noise Survey (2014) - Lloyd’s Register + UK P&I C...
Guidance Notes on Fire-Fighting Systems - ABS [2017, PDF]
Ship to Ship transfer Plan [sample] - DYNAMARINe [2013, PDF]
The time now is: Today 03:45
