Ferreirolo ®   10-Mar-2021 19:24
Manual do Contêiner
Year: 2021
Language: portuguese
Author: Marcos Machado da Silveira
Genre: Technical book
Publisher: Marcos Machado da Silveira
Edition: 1
ISBN: 978-65-00-16043-7
Pages count: 120
Description: The global economy depends on the regular exchange of goods. Any damage results in a waste of resources. Loss prevention measures are not only economically necessary, but also directly protect the environment.
Transport practice surveys revealed that almost seventy percent of all packaged containers, swap bodies, road and rail vehicles or other cargo transport units have deficiencies in the packaging and packaging of cargo that can result in damage. The purpose of this Container Manual is to prevent damage caused by negligent packaging and improper cargo peeling.
The author's original intention was to present mainly good examples of packaging and, to complement these, some bad examples as an impediment. However, the real situation was so bad that he was unfortunately compelled to write the Manual so that lessons could be learned from the load protection mistakes that had been made. Detailed comments are provided on how these errors can be corrected or avoided. The author deeply regrets the fact that so few shipments of properly filled containers could be found in practice, which could serve as good examples for a Manual.
Even a manual that has been edited and updated over many years cannot take into account all the variants found in practice, and this Manual itself cannot make any claim to integrity, being less than comprehensive or perfect in many parts. Nevertheless, it is being made available to the public in its current form, in the hope that it will contribute, at least, to the prevention of damage and loss. The author hopes that it will be possible to gradually update this Manual so that it becomes a useful source of advice for all those responsible for packaging and peeling cargo transportation units.
A economia global depende do intercâmbio regular de mercadorias. Qualquer dano resulta em desperdício de recursos. As medidas de prevenção de perdas não são apenas economicamente necessárias, mas também protegem diretamente o meio ambiente.
Pesquisas sobre a prática de transporte revelaram que quase setenta por cento de todos os contêineres embalados, caixas móveis, veículos rodoviários e ferroviários ou outras unidades de transporte de carga apresentam deficiências na embalagem e no acondicionamento da carga que podem resultar em danos. O objetivo deste Manual do Contêiner é evitar danos causados por embalagem negligente e peiação inadequada da carga.
A intenção original do autor era apresentar principalmente bons exemplos de embalagem e, para complementar estes, alguns exemplos ruins como um impedimento. No entanto, a situação real era tão ruim que ele infelizmente foi compelido a escrever o Manual de forma que lições pudessem ser aprendidas com os erros de proteção de carga que haviam sido cometidos. Comentários detalhados são fornecidos sobre como esses erros podem ser corrigidos ou evitados. O autor lamenta profundamente o fato de que tão poucos carregamentos de contêineres devidamente peiados pudessem ser encontrados na prática, o que poderia servir como bons exemplos para um Manual.
Mesmo um manual que foi editado e atualizado ao longo de muitos anos não pode levar em conta todas as variantes encontradas na prática, e o presente Manual em si não pode fazer qualquer reivindicação de integridade, sendo menos do que abrangente ou perfeito em muitas partes. Não obstante, está sendo disponibilizado ao público em sua forma atual, na esperança de que contribua, pelo menos, para a prevenção de danos e perdas. O autor espera que seja possível atualizar gradualmente este Manual para que se torne uma fonte útil de conselhos para todos os responsáveis pela embalagem e peiação das unidades de transporte de carga.
manual_do_container_v1_2021.pdf
Download [5 KB]
Container Handbook - AG Winfried Strauch [2008, PDF]
TRANSPORTE MARITIMO CARGAS, NAVIOS, PORTOS E TERMINAIS - Petronio Sa Benevides Magalhaes [2011, PDF]
MANUAL PARA PROJETO DE DEFENSA - FENDER TEAM [2014, PDF]
Plano Nacional de Logística Portuária - Sumário Executivo - Ministério da Infraestrutura do Brasil…
Plano Mestre - Complexo Portuário de Natal - Secretaria Nacional de Portos [2018, PDF]
Dicionário Básico Portuário - Assessoria de Comunicação da Administração dos Portos de Paranaguá e…
ECDIS: Conceitos e operaçao - Marcos Machado da Silveira [2013, PDF]
Plano Mestre do Complexo Portuário de Santos - Volume 3 - Mônica de Souza [2019, PDF]
Convenio De Líneas De Carga Edición Consolidada 2018 - Dirección General de la Marina Mercante…
Navegar é Fácil - Geraldo Luiz Miranda de Barros [1999, PDF]
The time now is: Today 14:13
