twicer ®   30-Oct-2020 21:19
PrimeShip Green EEOI-Onboard
Year: 201x
Version: 1.0.6.0
Developer: NIPPON KAIJI KYOKAI
64-bit OS compatibility: unknown
System Requirements: OS: Windows 7 / Vista SP2 or later / XP SP3
Browser: Internet Explorer 8 / 7 / 6
Microsoft .NET Framework 3.5
Memory: 1GB or greater (recommended)
HDD: 600MB hard drive space (recommended)
Description: PrimeShip-GREEN/EEOI is a system used for the calculation and analysis of EEOI for the owners and operators of NK classed vessels.
PrimeShip-GREEN/EEOI is a system used for the calculation and analysis of EEOI (Energy Efficiency Operational Indicator) of a ship in order
to check GHG (CO2) emission levels during ship operation based on IMO guidelines (MEPC.1/Circ.684). Users can visually confirm variations in
energy efficiency and its contributing factor by displaying EEOI calculation results in a trend chart. PrimeShip-GREEN/EEOI is expected to help
facilitate the improvement of the energy efficiency of ships.
PrimeShip-GREEN/EEOI consists of two specialized applications: "EEOI-Onboard" for data input, and "EEOI-Web" for EEOI calculation and analysis.
Easy registration of ships to the system is available by using a data link with NK-SHIPS.
PrimeShip-GREEN/EEOI users can access after logging in through the web service portal.
Manuals and Guides included.
Additional info
EEOI Key Code included
Download [35 KB]
masterkazakov   21-Jan-2023 14:19
Добрый день!Пожалуйста подскажите почему не работает EEOI Key CodeЯ все делал по инструкции, но код он не принимаетПишетThe selected Key Code file is not correct. Please select the KeyCode file distributed from the management companyПожалуйста вышлите правилный ключСпасибоАлександр
twicer ®   21-Jan-2023 21:54
masterkazakov, Ключ (как и сама программа) рабочий!, но для "внутреннего" (on board) использования. Ни какие данные НЕ могут быть отправлены ClassNK и/или судовладельцу для анализа, контроля и т.д. и т.п.. Это просто и понятно, что для "официального" использование судно должно быть зарегистрировано под ClassNK и судовладелец обеспечил PrimeShip Green EEOI-Onboard на борту его судна. как-то так, наверное... :-/
Guest   22-Jan-2023 02:03
Спасибо за ответ. То и есть что я не могу запустить программу у себя дома на компьюторе
masterkazakov   22-Jan-2023 02:07
twicer ®   22-Jan-2023 02:17
masterkazakov, в том-то и дело, что основываясь на прилагаемых screenshots запускается хоть из дома хоть из космоса, только НЕ получить мониторинга от ClassNK...
или у вас не все add-ons стоят, .netframe-ы и т.п. - в раздаче все есть.
masterkazakov   23-Jan-2023 01:47
twicer, Добрый вечер!
Извените но я что то не понимаю наверно.
1 Скачал ваш софт
2 В папке EEOI classnk выбрал и запустил установачный файл "setup"
3 Все пошло согласно вашего мануала по установки
4 когда дело дошло до вода ключа - сделал ка в мануале написано
Вот тут и все не принимает код
Дополнительно ни чего не устанавливал
так как мануал для Win XP
У меня Win 10 pro по последнему пакету обновлений
Может на win 10 не работает?
Хотелось бы установить прогамму я вам в личку напишу свой номер тел
Зарание Спасибо
Digital Course Recorder Data Analysis Software - Tokyo Keiki Inc. [2017]
ClassNK Guidelines - ClassNK [2025, PDF]
ISSA Ship Stores Catalogue 2013 Edition (Portable) v.2.0 [2013]
Wind Assisted propulsion Systems for ships - ClassNK [2024, PDF]
LR RuleFinder 9.40 (2024) - LR [2024, CHM]
Guidelines on Preventive Measures against Parametric Rolling - ClassNK [2023, PDF]
LOAD Ace Marine Loading Computer [Bulk Carrier] on CD v.7.1 - NIPPON HAKUYO electronics [201x]
LoadPlus - Loading computer application for 8300 DWT Oil/Chemical Tanker v.1.0.0 build 2347 - HANLA ...
Guidelines on Preventive Measures against Parametric Rolling [2023, MP4]
HMC ECDIS v.5.1 [2014]
The time now is: Today 02:56
