twicer ®   05-Oct-2020 00:30
StormGeo [AWT] BonVoyage System Onboard Edition
Year: 2018
Version: 8.3.0.2
Developer: © Copyright 2020 StormGeo
64-bit OS compatibility: yes
System Requirements: Windows any Version
Crack: Not needed. * Meteo Subscription Required!
Description: Designed with Masters and bridge environment in mind, StormGeo's BonVoyage System™ (Classic BVS)
provides you with user-friendly route optimization, voyage planning and reliable weather forecast in a simple-to-install,
intuitive application. Bon Voyage System (BVS) designed from the ground up and with the captains needs in mind. BVS puts
voyage planning right in the hands of the captain and helps him plan and determine the safest, most fuel-efficient route.
BVS as weather and route optimization module of NaviPlanner (NaviPlanner BVS) allows you to Import routes from any ECDIS
Monitor weather conditions / Optimize the route by least cost, required arrival time or least time en route Check for intersecting
ENCs, order new ones or update as required / Transfer your optimized route instantly to the ECDIS via NaviUpdate, without the
need for USB drives/Create a fully compliant voyage plan/Obtain ports information / Generate a Voyage Report.
*** Manuals, Guides and Training Video included ***
*** Download for self-study and training ***
Download [20 KB]
BonVoyage System (BVS7) v.7.1.0.1 [2015]
VVOS: Vessel and Voyage Optimization Solution - User Guide - CMap [2xxx, PDF]
CoreDatabase for Voyager Planning Station 8 | Week 11/24 - © Voyager Worldwide [2024]
Maxsurf v25.00.00.280 - Bentley [2025]
C-MAP Plan2Nav - Marine Navigation v.1.6.1 - C-MAP by Jeppesen [2016] [Android]
VovSoft Container Loading Calculator v.1.5 - Vovsoft [2024]
Passage Manager 6.0 + MetManager 7.0 - ChartCo [2016]
The time now is: Today 16:51
