zxc ®   22-Feb-2015 01:01
Bunkering Best Practices: Protecting People and the Environment
Year: 2013
Country: USA
Genre: Environment
Playtime: 14:45
Translation: Single voice
Director: Pacific States/British Columbia Oil Spill Task Force
Description: A single oil spill can cost millions of dollars in clean up expenses, provoke harsh regulatory responses, and increase monitoring and limits on bunkering operations. By following the best practices in this video, companies can help prevent costly and dangerous spills.
Topics
  • Identify the steps of a safe oil transfer procedure
  • Learn the components of a preloading plan
  • See preparations for safe fuel transfer, including necessary inspections
  • Understand typical distractions during the oil transfer and how to avoid them
  • Recognize why and when to shut down the transfer process
Quality: HDTV
Format: MP4
Video codec: Other MPEG4
Audio codec: AAC
Video: 1280 x 720 / 16:9
Audio: 256 Kbps / 48.0 KHz
More...
U.S.A., Washington, Seattle, March 7, 2013 - For the first time nearly 20 years, a new video on best practices for bunkering operations (the transfer of fuel to a vessel) has been released. Entitled Bunkering Best Practices: Protecting People and the Environment, the 14-minute training video is the result of cooperative efforts from members of the Pacific States/British Columbia Oil Spill Task Force, including Alaska, British Columbia, California, Hawaii, Oregon and Washington, in conjunction with Maritime Training Services in Seattle.
The idea for the project originated with the Office of Spill Prevention and Response (OSPR) in California. Ted Mar, Chief of OSPR Marine Safety, says "After a high-profile oil spill resulted from a bunkering operation in San Francisco Bay in 2009, the OSPR Administrator asked California's five Harbor Safety Committees (HSC) to develop 'Best Bunkering Practices.' Once developed, the HSC's thought a video might be the most effective way to communicate these best bunkering practices to the maritime community."
Funded by the Pacific States and BC OSTF, and led by the California OSPR and Washington Department of Ecology, the new video demonstrates bunkering best practices applicable to the aforementioned states and British Columbia, with a section on state-specific regulations for Washington and California.
The new bunkering video presents the steps of a safe oil transfer procedure, the components of a pre-loading plan and inspections, and emphasizes how to avoid distractions during the transfer process. The producers of the film state that proper crew training, including knowing when and why to shut down a bunkering operation, will result in reduced oil spills caused by human error.
"The OSPR believes that following the bunkering best practices presented in this video will help prevent spills during bunkering operations, providing the best achievable protection to the West Coast's natural resources," said Ted Mar.
The documentary-style video includes interviews with government officials, tug and barge operators, and tanker men, which helps inform crews on board arriving vessels about bunkering regulations in the regions mentioned above.
Chip Boothe, Spills Prevention Section Manager for the Washington Department of Ecology, said, "While vessel accidents may have the greatest potential for catastrophic oil spills, bunkering operation spills are the most predominant source of oil pollution from commercial vessels. If every vessel crew followed these common sense practices for their bunkering operations, it would prevent the principal source of commercial vessel oil spills occurring within our ports."
A single oil spill can cost millions of dollars in clean up expenses, provoke harsh regulatory responses, and increase monitoring and limits on bunkering operations. By practicing the responsible oil transfer procedures outlined in Bunkering Best Practices: Protecting People and the Environment, companies and crews can help prevent costly and dangerous spills.
Media Info
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Format settings, GOP : M=3, N=33
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 14mn 45s
Bit rate : 7 994 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 24.000 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.361
Stream size : 844 MiB (99%)
Language : English
Encoded date : UTC 2013-02-21 21:30:41
Tagged date : UTC 2013-02-21 21:30:41
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Color range : Limited
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 14mn 45s
Source duration : 14mn 45s
Bit rate mode : Variable
Bit rate : 61.6 Kbps
Maximum bit rate : 101 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 44.1 KHz
Compression mode : Lossy
Stream size : 6.50 MiB (1%)
Source stream size : 6.50 MiB (1%)
Language : English
Bunkering_Master_2_13_13.mp4
Download [17 KB]
zaskar   15-Aug-2018 16:44
A PDF manual related to this video can be downloaded from here
Bunkering Best Practices - Sarah Thompson, Mike Lynch, Pacific States/British Columbia Oil Spill Task Force [2014, PDF]
Author: Sarah Thompson, Mike Lynch, Pacific States/British Columbia Oil Spill Task Force | Year: 2014 | Language: english | Format: PDF | Quality: eBook | Pages count: 40 | Genre: Manual
Open released by zaskar
3
Sail Canada Basic Coastal Navigation Course Video, Session 2 - Wavelength Sailing School [2017, MP4]
Sail Canada Basic Coastal Navigation Course Video, Session 1 - Wavelength Sailing School [2017, MP4]
Wartsila SW38 Maintenance [199X, AVI/VOB/PDF]
Bunkering Best Practices - Sarah Thompson, Mike Lynch, Pacific States/British Columbia Oil Spill…
Северный морской путь. Дорога арктической жизни - Алексей Ермилов [2023, AVI]
Mighty Cruise Ships (Seasons 1-3) [1080p+720p] [2014-2019, MKV]
Mighty Cruise Ships (Season 4) [1080p] [2021, MKV]
How to work Westfalia D-Type Separators [2001, AVI]
Dismantling of Alfa Laval S-Type (Video) [MPG]
MAN B&W - L+V 28/32 - Removal and Overhaul of cover, piston and liner [199x, MP4]
The time now is: Today 12:32
