vitbar192 ®   21-Jul-2020 13:57
Marine Acoustics - Direct and Inverse Problems
Year: 2003
Author: Buchanan J.L., Glbert R.P. at all
Genre: Handbook
Publisher: SIAM: Society for Industrial and Applied Mathematics
ISBN: 0898715474
Pages count: 349
Description: This book presents current research trends in the field of underwater acoustic wave direct and inverse problems. Until very recently, little had been published concerning model-based inversions of the boundaries and material constants of finite-sized targets located in either the water column or the sediments. This text is the first to investigate inverse problems in an ocean environment, with a heavy emphasis placed on the description and resolution of the forward scattering problem.
Marine Acoustics: Direct and Inverse Problems emphasizes computation of Green's Functions with new material added for elastic and poro-elastic seabeds. This timely publication addresses many areas of practical interest related to underwater acoustical imaging, including ecological survey and cleanup, protection of open water harbors, maintenance of offshore petroleum and gas enterprises, and other areas of environmental and military concern.
The ocean-seabed system is an acoustic waveguide, and this is the only book that treats inverse problems in a waveguide. The propagation of acoustic waves in this system is treated for various types of seabeds and the direct and inverse problems are considered in realistic ocean environments. The inverse problem is to determine the shape of an impenetrable or penetrable object, or to determine the coefficients describing the seabed. This is done by acoustically illuminating the seabed and investigating the scattered field.
Buchanan J.L., Glbert R.P. at all Marine Acoustics - Direct and Inverse Problems, 2003.pdf
Download [20 KB]
Elements of Ocean Engineering - ROBERT E. RANDALL [2010, PDF]
Advanced Research in Naval Engineering - Anthony A. Ruffa Bourama Toni [2018, PDF]
Seafloor Processes and Geotechnology - Ronald C. Chaney, Gideon Almagor [2016, PDF]
Construction of Marine and Offshore Structures - Ben C. Gerwick, Jr [2007, PDF]
Sea loads on ships and offshore structures - O.M. Faltinsen [1999, PDF]
Radio Wave Propagation in the Marine Boundary Layer - Alexander Kukushkin [2004, PDF]
Hurricane Generated Seas - Elsevier Ocean Engineering Book Series: Volume 8 - Michel K. Ochi [2003, ...
Handbook of Marine Craft Hydrodynamics and Motion Control - Fossen T. [2021, EPUB]
Principles Naval Architecture - Vibration - William S. Vorus [2010, PDF]
Advanced Model Predictive Control for Autonomous Marine Vehicles - Yang Shi · Chao Shen · Henglai We...
The time now is: Today 13:31
