A13x ®   10-Jul-2020 21:37
MAN B&W - AutoChief C20 Instruction Manual for MAN B&W MC Engines with Fixed Propeller installation- [2004, PDF]
Year: 2004
Author: © Norway Kongsberg Maritime AS
Genre: MANUAL
Number of pages: 125
Description: AutoChief C20 Instruction Manual for MAN B&W MC Engines with Fixed Propeller installation
This manual is generated through the configuration tool called Seamate. The manual is therefore customised for each system delivery. The intention with this manual is to explain the functionality for each mayor component and the total system as it’s configured for each delivery. How to operate the system is described in a manner where we assume that the system is in operation and that normal operations shall be carried out. This manual is not made for advanced troubleshooting.
AA-0381a- ACC20 B&W MC Instruction manual.pdf
Download [4 KB]
A13x ®   10-Jul-2020 21:51
66963A13x, MAN B&W - AutoChief® C20 Kongsberg Propulsion Contr...nual [2005, PDF] - повтор - проверяйте, пожалуйста, по поиску.
Прошу прощения, возможно ли поменять заголовок? Так как он совпадает с вашей ссылкой это верно, но по ссылке autochief для MAN ME на судне с ВРШ. У меня для MAN на судне с винтом фиксированного шага.
5
A13x ®   11-Jul-2020 13:28
Vitbar192, Странно, но у меня нет доступа.
vitbar192   14-Jul-2020 05:28
A13x, Попробуйте сейчас. Если не получится, пришлите новый вариант, я вставлю сам.
vitbar192   16-Jul-2020 21:03
A13x, Определитесь с годом издания - 2003 или 2004? И отредактируйте.
MAN B&W - AutoChief® C20 Kongsberg Propulsion Control System Instruction Manual for MAN B&W ...
Kongsberg AutoChief®C20 MAN MC Engines Fixed Pitch Propeller - Konsberg Maritime A.S [2008, PDF]
Wartsila / Kongsberg Control system for RT-FLEX engine - AutoChief 20 [2009, PDF]
NYK - LPG Stars (Shipboard Training and Assessment Recording System) - NYK [2006, PDF+MP3]
Environment Management System (EMS) Manaul - Synergy Maritime Pvt. Ltd. [2021, PDF]
International Guidelines for The Safe Operation of Dynamically Positioned Offshore Supply Vessels - ...
Berg Propulsion. CPP System. Operation & Service Manual - Berg Propulsion [2009, PDF]
Environment Energy Management System (EEMS) Manaul - Synergy Maritime Pvt. Ltd. [2022, PDF]
Environment Energy Management System (EEMS) Manaul - Synergy Maritime Pvt. Ltd. [2023, PDF]
The time now is: Today 02:57
