vitbar192 ®   05-Jul-2020 07:00
The Cruising Multihull
Year: 1996
Author: White C.
Publisher: International Marine/Ragged Mountain
ISBN: 0070698686
Quality: Photo of pages
Pages count: 282
Description: Long typecast as the hotrods of the sea--fast but dangerous--modern cruising multihulls actually are among the safest and most comfortable cruising sailboats available. Modern multihulls offer significant advantages over single-hull sailboats: They sail faster, have more living space, they're more comfortable, more stable, they can sail safely in much shallower water, and, because their stability comes from widely spaced hulls and not from tons of lead hung off the keel, they don't sink. Given the ultimate disaster, which would you choose: A capsized yet habitable boat, floating awash, or a self-righting boat sitting at the bottom of the ocean? And multihulls are fast. A typical weekend cruiser's circle of operations might double if he switches to a multihull. A transatlantic voyage might be cut by a third. No less an organization than the U.S. Navy decided that applications requiring an extremely steady platform at sea were best suited to, of all things, a catamaran. The Cruising Multihull supplies the reader with all the latest information about design, construction, rigs, seamanship, safety, and a point-by-point rebuttal of the "accepted wisdom" concerning multihull dangers. It will help you decide whether a multihull is right for you; which multihull--cat or tri--is best for your needs; whether you should build one yourself, have one built, or buy one off the rack. And, of course, The Cruising Multihull shows you how to get the most from your boat. "I don't know of a more thorough survey of modern cruising multihulls than this book. For strangers to these boats who want to know more about them, as well as for multihull sailors eager to learn from a capable, articulate designer and sailor with his own point of view, I enthusiastically recommend The Cruising Multihull."--John Rousmaniere "Finally, a multihull voice which does not proselytize. Instead, logic and information pack the pages of Chris White's . . . The Cruising Multihull."--WoodenBoat
White C. The Cruising Multihull, 1996.pdf
Download [13 KB]
Sailors Book of Small Cruising Sailboats - Henkel S. [2010, PDF]
Fix It and Sail - Brian Gilbert [2005, PDF]
Aero-Hydrodynamics and the Performance of Sailing Yachts - Fossati F. [2010, PDF/DjVu]
The New Kayak Shop - More Elegant Wooden Kayaks Anyone Can Build - Kulczycki C. [2000, PDF]
The building of a wooden ship - Davis C.G. [1918, PDF]
Spurr’s Guide to Upgrading Your Cruising Sailboat - Spurr D. [2006, PDF/EPUB]
Fix It and Sail - Everything You Need to Know to Buy and Restore a Small Sailboat on a Shoestring -…
The Sailor’s Book of Small Cruising Sailboats - Henkel Steve [2010, PDF]
Rough Weather Seamanship for Sail and Power: Design, Gear, and Tactics for Coastal and Offshore…
The seaworthy offshore sailboat - a guide to essential features, gear, and handling - Vigor J.…
The time now is: Today 16:25
