paolina_3 ®   22-Jun-2020 17:52
Guidelines for Offshore Marine Operations (GOMO), 2020
Year: 2020
Author: various authors
Pages count: 293
Description: Shipboard operations, to support and supply off-shore facilities, present a high level of risk, due to the nature of the work involved, and the challenging environments in which these facilities are often located. To reduce and manage these risks, the industry has produced the Guidelines for Offshore Marine Operations (GOMO), which gather together the best practices for safe operations.
This document has a standard global approach, with the purpose to provide guidance in the best practices, which should be adopted to ensure the safety of personnel on board all vessels servicing and supporting offshore energy sector facilities, and to reduce the risks associated with such operations. It particularly relates to operations of offshore facilities and operations of vessels.
Additional info:
This document update and revise previous document in some parts/chapters. Refer to contents screenshots for detailed revision/date/status of each part or chapter.
Guidelines for Offshore Marine Operations (GOMO) 2020.pdf
Download [5 KB]
Guidelines for Offshore Marine Operations (GOMO) - OCIMF, IMCA, MSF, and others [2024, PDF]
Guidelines for Offshore Marine Operations - OCIMF, IMCA, MSF, and others [2025, PDF]
Guidelines for Offshore Marine Operations - Norwegian Shipowners Association & Others [2013, PDF]
Offshore Marine Operations - Adam Hassan [2022, PDF]
Deck Cargo Management Onboard Offshore Vessels - Oil Companies International Marine Forum [2018, PDF...
NWEA Guidelines for the Safe Management of Offshore Supply and Rig Move Operations - Working Group O...
Managing the Risk of Blackouts - DNV [2022, PDF]
International Consensus Standards For Commercial Diving and Underwater Operations, 6.4 Edition - ADC...
Offshore Vessel Operations in Ice and/or Severe Sub-Zero Temperatures In Arctic and Sub-Arctic Regio...
Guidelines for Lifting Operations - IMCA [2007, PDF]
The time now is: Today 17:09
