jackaubrey77 ®   05-May-2020 13:53
Teoría del buque : ola trocoidal, movimientos y esfuerzos
Year: 1998
Language: spanish
Author: Olivella Puig, Joan
Publisher: Universitat Politècnica de Catalunya
Edition: 1998
ISBN: 9788483012598
Pages count: 211
Description: The movement of the ship is subject to the whim of the waves. Understood this, the seafarer should seek the response to the commitment that exists between the ship's buoyancy and stability in order to carry out a measured mission under the conditions of sea that the climatology holds and, at the same time, that the hull structure suffers as little as possible. This book deals with two truly important topics, such as the rotating movement of the vessel between wave and nodding waves and the vertical transmission movement, and longitudinal efforts, cutting efforts, the freading moment, and the moment of the torsion of the hull in quiets and waves. The reader can find in its content input from practical order, without the need to enter the knowledge of why. The study, for its part, will be able to find the basis for the trocoidal wave, the movement of the vessel between waves and the efforts it is suffering, which will naturally allow it to gain more benefit and have a stronger basis for making its decisions in real practice.
El movimiento del buque queda sujeto al capricho de las olas. Bien entendido esto, el marino debe buscar la respuesta al compromiso que existe entre que el buque mantenga su flotabilidad y estabilidad para realizar una misión determinada bajo las condiciones de mar que la climatología le depare y, al mismo tiempo, que la estructura del casco sufra lo menos posible. En este libro se tratan, pues, dos temas verdaderamente importantes, como son los movimientos de rotación del buque entre olas de balance y cabeceo y el movimiento de traslación vertical, y los esfuerzos longitudinales, los esfuerzos cortantes, el momento flector y el momento de torsión del casco en aguas quietas y entre olas. El lector puede encontrar en su contenido aportaciones de orden práctico, sin necesidad de entrar en el conocimiento del por qué. El estudioso, por su parte, podrá hallar los fundamentos de la ola trocoidal, del movimiento del buque entre olas y de los esfuerzos que sufre, lo que lógicamente le permitirá sacar un mayor provecho y tener una base más solida para tomar sus decisiones en la práctica real.
Teoría del buque-Ola trocoidal, movimientos y esfuerzo-Joan Olivella Puig
Download [13 KB]
Teoría del buque : flotabilidad y estabilidad - Olivella Puig, Joan [1995, PDF]
Teoría del buque : estabilidad, varada e inundación - Olivella Puig, Joan [1996, PDF]
Teoría del buque : flotabilidad y estabilidad : problemas - Olivella Puig, Joan [1995, PDF]
Teoría del buque - Antonio Bonilla de la Corte [1979, PDF]
Teoría del Buque - Cesáreo Díaz Fernández [1972, PDF]
Design of a boat electric propulsion system based on solar energy - Bigorra E.M. [2018, PDF]
Teoría Del Buque - Intoducción A La Propulsión De Buques - Antonio Baquero [2011, PDF]
A Manual of Naval Architecture - W.H. White [1894, PDF]
Proceedings of 19th Annual General Assembly (AGA19) of the International Association of Maritime Uni...
Elementos De Arquitectura Naval - Mandinelli, Antonio [1986, PDF]
The time now is: Today 02:56
