Gogo81 ®   16-Apr-2020 05:13
The Boat Data Book
Year: 2004
Author: Ian Nicolson
Publisher: Sheridan House
Edition: Fifth Edition
Format: EPUB
Pages count: 287
Description: This book is for owners, crew, boatbuyers, charterers, chandlers, builders, repairers, designers, draughtsmen
and students. In fact, for anyone concerned with boats and ships. One of its most valuable uses is saving time
and trouble when specifying anything. By simply quoting a page anyone can order equipment without having
to look up the correct size and write out lengthy details. An owner can phone a marina or chandler and simply
say: Tut a new anchor on my boat. Size as specified in Boat Data Book\ Designers can reduce long lists of
rigging to: 'As detailed in Boat Data Book, page 115, column for yachts between 9 m and 11 m\ Anyone buying
a boat can check the standard of its equipment by referring to the hsts in this book. There is a widespread
practice of fitting boats with totally inadequate anchors, chain, winches and so on. Many second-hand boats
offered for sale are found to have inadequate safety gear, and much of what is on board is often out of date.
Reference to pages 26 to 35 will show what is needed. When designing or acquiring a boat it is important
to check dimensions of berths, galley top heights and so on. There is a tendency also to save on building
costs by fitting furniture which is under-size and as a result inconvenient, besides being uncomfortable to use.
Chapter 6 on Design gives many basic dimensions, standard, recommended minimum sizes and so on.
The Boat Data Book
Boat Data Book - Nicolson I. [1999, PDF]
The Boat Data Book - Nicolson I., Nicolson R. [2014, EPUB]
The Offshore Yacht - Tim Thornton [1984, PDF]
Build your own boat completing a bare hull - Ian Nicolson [1996, PDF]
Be Your Own Boat Surveyor - Dag Pike [2014, EPUB]
Surveying Yachts and Small Craft - Paul Stevens [2013, ePUB] - Paul Stevens [2013, EPUB]
Improve Your Own Boat - Nicolson I. [1986, PDF]
Boatowner’s Sheet Anchor: a Practical Guide to Fitting Out, Upkeep and Alteration of the Small…
Rigging Small Sailboats - Hankinson K. [1973, PDF]
The Construction and Fitting of the English Man of War 1650 - 1850 - Peter Goodwin [1987, PDF]
The time now is: Today 16:07
