vitbar192 ®   08-Feb-2020 10:02
Devlin's Boat Building - How to Build Any Boat the Stitch-and-Glue Way
Year: 1995
Author: Devlin S.
Publisher: International Marine/Ragged Mountain Press
ISBN: 0071579907
Pages count: 198
Description: Why is stitch-and-glue boatbuilding so popular?
Any number of construction methods will produce a beautiful boat. But for the backyard builder with limited experience and a tight budget, the choice is not so complicated. Traditional plank-on-frame and cold-molded construction require complicated lofting and building molds-to say nothing of expensive tooling and lots of time. Stitch-and-glue construction, on the other hand, can produce the same results with a substantial savings in time and money. The process is quicker, easier, uses fewer parts, and produces a boat that is much easier to maintain-without the building molds and with only the simplest lofting. For tools, you need little more than a circular saw, a sander/polisher/grinder, a block plane, a framing square, a level, and a tape measure.
Sam Devlin has elevated stitch-and-glue boatbuilding to an artform, and his graceful designs have attracted the attention of backyard builders across the country. Here is all you need to know to build the boat of your dreams, whether it's a 7-foot dinghy or a 40-foot power cruiser. Devlin's Boatbuilding: How to Build Any Boat the Stitch-and-Glue Way shares the wisdom of his 16 years of experience designing, building, and helping others build his fleet of small sail- and powerboats.
It's all here, from choosing a design and setting up shop to painting the finished hull and launching. There is also a gallery of Devlin's designs and a detailed appendix listing sources for tools and other materials.
Devlin S. Devlin's Boatbuilding - How to Build Any Boat the Stitch-and-Glue Way, 1995.pdf
Download [15 KB]
The laminated wood boatbuilder A step-by-step guide for the backyard builder - Miller Hub [1993, PDF...
Everything You Ever Wanted to Know About Boat Building - Spira J.J. [2006, PDF]
Building Outrigger Sailing Canoes: Modern Construction Methods for Three Fast, Beautiful Boats - Gar...
Ultrasimple Boatbuilding - 17 Plywood Boats Anyone Can Build - Atkin C. [2008, PDF]
Boatbuilding with Plywood and Epoxy - Stambaugh C. [2008, PDF]
Building the Uqbar Dinghy - Redjeb Jordania [2014, PDF]
Ultralight Boatbuilding - Hill T.G. [1987, PDF]
Illustrated Guide for Building a Spira International Stitch And Glue Boat - Spira J.J. [2010, PDF]
The New Kayak Shop - More Elegant Wooden Kayaks Anyone Can Build - Kulczycki C. [2000, PDF]
Lofting a boat a step by step manual - Roger Kopanycia [2011, PDF]
The time now is: Today 17:10
