Gogo81 ®   07-Feb-2020 17:58
Modern Ocean Cruising: Boats, gear and crews surveyed
Year: 1983
Author: Jimmy Cornell
Publisher: Granada Publishing
Edition: First
Pages count: 200
Description: This book has it all. It tells you the recommendations of those who actually live and travel in these yachts around the world. You can cut through the salesmen at the stores and look into the real meat of the issues involved with sailing. You can pick and determine the engines, and the types of materials, as well as the configuration of the boat most suited for your given personality and inclination. This is a must read for the yacht builder and dreamer in all of us.
Modern ocean cruising boats, gear and crews surveyed
Download [8 KB]
Ocean Cruising Survey: An Appraisal of Boats, Gear and Crew - Jimmy Cornell [1986, PDF]
World Cruising Survey : An Overview of Boats, Gear and Life on Board - Jimmy Cornell [2002, PDF & DO...
Spurr’s Guide to Upgrading Your Cruising Sailboat - Spurr D. [2006, PDF/EPUB]
101 Tips and Hints for Your Boat - Damour J. [1981, PDF]
World Cruising Routes - Fifth Edition - Jimmy Cornell [2002, PDF]
World Cruising Handbook - Cornell J. [1996, PDF]
Buehler’s Backyard Boatbuilding - George Buehler [1991, EPUB]
Tips from Jimmy Cornell - Cornell J. [2019, PDF]
World Voyage Planner - Planning a Voyage from Anywhere in the World to Anywhere in the World - Corne...
The time now is: Today 02:55
