Gogo81 ®   04-Feb-2020 22:27
Nautical emergencies : seamanship for the unexpected
Year: 1984
Author: Tony Meisel
Publisher: W.W. Norton & Company
Edition: First
ISBN: 0-393-03285-X
Pages count: 151
Description: Emergencies at sea are much the same as those on land, except for the unpredictable motion, the vagaries of weather, and the important fact that you cannot call your neighbor or the local police for aid. You are on your own. You must possess or learn the skills to bring your vessel safely to port or, perhaps, even to survive.
Nautical Emergencies was written with the average yachtsman in mind: one who knows how to sail, and has experienced most of the usual...groundings, dragging anchors, torn sails and dying engines. Here, you will find a number of common and uncommon contingencies with direct responses to solve or at least lessen their impact.
In each case, step-by-step instructions are given , telling you exactly what to do, in order. Following are instructions that show you exactly how to solve your particular problem. And finally, each section contains detailed, explicit elaborations on the solutions, keyed to the illustrations.
Nautical emergencies seamanship for the unexpected
Download [6 KB]
Cruising under sail & power - Tony Meisel [1990, PDF]
Singlehanding: a sailor’s guide - Tony Meisel [1986, PDF]
Practical Boat-Sailing - A Concise and Simple Treatise - Frazar D. [1879, PDF/EPUB]
Practical Boat-Sailing - A Concise and Simple Treatise - Frazar D. [2022, PDF/EPUB]
The boating emergency manual - sail & power - Tony Meisel [1989, PDF & EPUB]
A Manual of Singlehanded Sailing - Tony Meisel [1981, PDF]
Yacht Navigation - My Way - Captain J. O. Coote [1988, PDF]
Modern Seamanship: A Comprehensive Reference Guide For All Recreational Boaters - Don Dodds [2000, P...
Under sail : equipment for the serious sailor - Tony Meisel [1982, PDF]
Rough Weather Seamanship for Sail and Power: Design, Gear, and Tactics for Coastal and Offshore Wate...
The time now is: Today 12:40
