arun25hyd ®   13-Jan-2020 08:22
Wartsila ZAV40S Marine Engine
Year: 200?
Author: Wartsila
Publisher: Wartsila
Pages count: 750
Description: The instructions contained in this Maintenance Manual are meant to contribute towards correctly handled mainte-
nance work to be carried out at specific intervals.
It has been assumed that the staff put in charge of such work possesses the required mechanical knowledge and practice.
Indications on the engine operation as well as the description of the function of specific systems are contained in the
Operating Instructions. In this manual, you can find also under group 0010---1 and 0040---1 explanation to the lay-out
and use of the Operating Instructions as well as of the Maintenance Manual.
More detailed instructions on the operation and maintenance of components from sub-suppliers can be gathered from
the instruction leaflets of the respective manufacturers.
Outside makes are, for example, such engine components which are not manufactured in accordance with drawings of
Wärtsilä Italia S.p.A.
The Maintenance Manual is subdivided into the following main divisions:
--- General guidelines for maintenance
--- Maintenance schedule
--- Clearance and wear tables, tightening values of screwed connections, masses (weights), seal rings
--- Design groups
--- Tools list
Clearance and Wear Table . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0352-1/A1
Fuel Injection Pump
Lubricating Oil and Fuel Oil Booster Pump . . . . . . . . . . . . . . . . . . with EngineDriven Pumps
Cylinder Cooling Water Pump . . . . . . . . . . . . . . . . . . . . . . . . . . . . . with EngineDriven Pumps
Raw Water Pump . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . with EngineDriven Pumps
Fuel Nozzle Cooling Water Pump . . . . . . . . . . . . . . . . . . . . . . . . . . with EngineDriven Pumps
Tightening Instructions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0355-1/A1
Tightening Values of Important Screwed Connections
Taking Lubricating Oil Samples for Laboratory Analysis . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0356-1/A1
Wartsila ZAV40s Manintenance manual, Operating Manual, Spare parte catlouge all in one folder.
Sulzer ZAV40S [PDF]
Download [7 KB]
Sulzer ZAV40S (Maintenance, Operation, Spare Parts) - Wärtsilä [2004, PDF]
Wärtsilä W26/W38 Maintenance Tools and Spare parts sets - Wärtsilä [2012, PDF]
Wärtsilä & Sulzer Service Bulletins [200x, PDF]
Main Engine Instructions for S50MC-C and K98MC - MAN B&W Diesel A/S [2010, PDF]
The Diesel Engine 7RT-flex82c Manual - Hyundai-Wartsila [2008, PDF]
Guide for judging condition of relevant piston-running components (liners, pistons and piston…
The time now is: Today 18:30
