mat-mat ®   25-Dec-2019 13:36
Sailor SE 406-II/ SGE 406-II Satellite EPIRB
Year: 2011
Author: Thrane & Thrane
Publisher: Thrane & Thrane
Edition: 1st
ISBN: 82-1073-002
Pages count: 36
Description: This Emergency Position Indicating Radio Beacon (EPIRB) is intended for carriage on
SOLAS and non-SOLAS vessels. When carrying an EPIRB on board you enjoy the
reassurance of a last resort safeguard against any life threatening incidents that may
occur anywhere in the world. Only operate the EPIRB in situations of grave and imminent
danger to life. False alerts endanger lives. Help prevent them by understanding how to
look after the EPIRB.
Cospas Sarsat system
EPIRBs transmit a unique emergency message identifier via the Cospas-Sarsat satellite
system which can determine your location anywhere on the earth’s surface. In most cases
the first emergency alert is received within 5 minutes of activation, depending on satellite
coverage at the time this can sometimes extend to around 45 minutes. When the
emergency alert message is received at a Rescue Co-ordination Centre (RCC) it is cross
referenced by the Unique Identifier Number (UIN) against user registration information.
Details of the alert will be forwarded to the appropriate local Search and Rescue (SAR)
teams. Keeping your vessels registration details up to date is critical to ensuring a quick
SAR response. If you have purchased the GPS version, it has a built-in GPS receiver
which can reduce the time for Search and Rescue teams to arrive on scene, as your
precise coordinates are transmitted within the first few minutes. Non-GPS versions are
pinpointed using Doppler Shift from the over-flying satellites.
EPIRBs have a secondary or ‘homing’ transmitter which allows SAR teams to direction
find or ‘home in’ on the EPIRB once they arrive on the scene. Once activated the EPIRB
will continue to transmit emergency alerts for a minimum of 48 hours.
SAILOR SE406II & SGE406II User manual.pdf
Download [5 KB]
Assignment and Use of Identities in the Maritime Mobile Service (Recommendation ITU-R M.585-8) - ITU...
Samyung SEP-500 GPS EPIRB User Manual - Samyung ENC [2009, PDF]
Thrane & Thrane - Sailor MF/HF System 6000A/6000B Radiotelex User manual - Thrane & Thrane A/S [2016...
National Search and Rescue Manual - AMSA [2018, PDF]
Australian GMDSS Handbook - Australian Maritime Safety Authority (AMSA) [2018, PDF]
Видеоуроки по ГМССБ - MorskoyKlub [MP4]
GMDSS 2.0: Charting the Digital Path to Safety - Saima Bukhari [2024, PDF]
Manual for Use by the Maritime Mobile and Maritime Mobile-Satellite Services (Volume 1 + Volume 2) -...
Global Mobile Satellite Communications Applications For Maritime, Land and Aeronautical Applications...
The time now is: Today 21:09
