methura ®   03-Dec-2019 14:29
Dear all,
Is there any software which can calculate and analyse fuel consumption of ships?
It can be based on manuel data or digital data from fuel flow machines etc?
Thank you
ivani   03-Apr-2024 06:07
what do you mean?
I don't know a program that do that specifically. It's a process first you have to know what the effective power would be to move your ship at a certain speed, I use maxsurf resistance with an efficiency of 55% to know how much power I need, then I have to select an engine according with the power I estimated before, and according with the consumption curves you estimate the fuel consumption in different cases or maneuvers.
That's only for the propulsion, you also need to know the consumption of other systems such as generators, pumps, etc.
I hope it can help you.
SEEMP PART III - LR [2022, DOC]
Waste Heat Recovery System (WHRS) for Reduction of Fuel Consumption, Emissions and EEDI - MAN…
Steel coils loading calculation
1A Unit Converter pro v.2.0.3 - Alexander Vollmar [2018] [Android]
Modern Ship Engineering, Design and Operations - Reusser C. [2021, PDF]
Subdivision Load Line???
Digital Twins for Vessel Life Cycle Service - Houxiang Zhang · Guoyuan Li · Hans Petter Hildre…
Celestial Calculations: A Gentle Introduction to Computational Astronomy - J. L. Lawrence [2019,…
Basic and advance of Diesel (Yanmar) - Yanmar [2016, PDF]
Uncertainty Analysis of Methods Used to Measure Ship Fuel Oil Consumption - J. Travis Hunsucker,…
The time now is: Today 12:33
