trupas ®   14-Nov-2019 23:22
The Seventy-Four Gun Ship: A Practical Treatise on the Art of Naval Architecture. Volume I: Hull Construction
Year: 1986
Author: Jean Boudriot
Genre: Practical guide
Publisher: Jean Boudriot Publications
ISBN: 2-903178-14-3
Pages count: 170
Description: As the main naval war machine at the end of the 18th century, the 74 Gun Ship was the result of a compromise, like every successful vessel. Her balance between strong guns and manoeuvrability offered by the 28 gun lower gundeck and firing 36 pound cannon-balls, made the "74" the perfect ship of the line. Since she moved more easily, she was much more useful in combat than the heavy 100 gun three-decker.
Her hull alone represented half of 3000 tons moving. 2800 hundred-year-old oak trees (a whole forest), and 600 tons of iron and wood bolts were needed for her construction. The hold and its orlop-deck could contain victuals for 6 months and water for 12 weeks. The gundeck had to bear the considerable weight of enormous 36-pdr guns, weighing 4 tons each. The upper deck, covered front and back with castles, carried lighter guns. This hull rose 7 meters above water and carried prodigious flights of sails. Each of the three masts, in three elements, rigged three floors of square sails and the main top-mast truck towered at 60 meters. This ship was well designed by her engineer and when correctly used by her crew, she performed superbly at sea in all weathers. In a fair breeze, she could exceed ten knots by sailing quartering.
Как основной военный корабль конца 18-го века, 74-х пушечники были результатом компромисса между сильной огневой мощью пушек и маневренностью. 28 пушек на нижней палубе, стрелявшие 36-ти фунтовыми ядрами, делали 74-х пушечники великолепными кораблями для линейного сражения. Более быстрые и маневренные, они были более успешными в бою, по сравнению с тяжелыми 100-пушечными трехдечными кораблями.
Только его корпус составлял около половины из полных трех тысяч тонн веса всего корабля. В основе его конструкции лежат 2800 столетних дубов и 600 тонн железных и деревянных болтов. Трюм и нижняя палуба корабля вмещали съестных припасов на 6 месяцев и воды на 12 недель. Орудийная палуба должна была выдерживать значительный вес громадных 36-фунтовых пушек, вес каждой достигал четырех тонн. Верхняя палуба вооружалась более легкими пушками.
Борт 74-х пушечника возвышался над водой на 7 метров. Каждая их трех мачт состояла из трех частей и несла паруса в три яруса. Клотик грот-мачты находился на высоте 60 метров, это примерно высота 20-ти этажного дома. Этот корабль был спроектирован со знанием дела, и при наличии обученной и тренированной команды, в любую погоду представлял реальную силу. При попутном ветре скорость корабля превышала 10 узлов даже при постановке всего четверти парусов.
I. Администрация портов и верфей. Основная структура. Корабельные инспектора. Сводная таблица.
II. Работа корабельных инспекторов. Высокие требования к военным кораблям. Изучение обводов корпуса. Водоизмещение корабля. Расчеты. Спецификация.
III. Работа корабельных плотников. Разметка на плазе.
IV. Материалы. Строевой лес. Пенька. Металлы. Другие материалы.
V. Оборудование на верфи. Стапель и киль-блоки. Подготовка леса. Закладка киля.
VI. Киль и штевни. Кормовые шпангоуты. Добавочные тимберсы. Усиление и обшивка трюма. Устройство палуб. Внутренняя обшивка выше трюма. Описание других работ внутри корабля. Внешняя обшивка корпуса.
VII. Скрепление и заделывание швов. Гвозди, крепежные детали. Гвоздевание, пробивание отверстий. Смола, пакля.
The seventy-four gun ship vol.1
Download [15 KB]
The Seventy-Four Gun Ship: A Practical Treatise on the Art of Naval Architecture. Volume III: Masts,...
The Seventy-Four Gun Ship: A Practical Treatise on the Art of Naval Architecture. Volume II: Fitting...
Modelling Sailing Men-of-War - An Illustrated Step-by-Step Guide - Reed P. [2000, PDF]
The history of the French frigate, 1650-1850 - Jean Boudriot [1993, PDF]
Le Fleuron 1729, Vaisseau De 64 Canons Du Constructeur Blaise Olivier (монография и чертежи) - Gerar...
The Seventy-Four Gun Ship (Vol/ 1) - Jean Boudriot [1986, PDF]
The Seventy-Four Gun Ship (Vol. 3) - Jean Boudriot [1987, PDF]
Architectura Navalis Mercatoria - The Classic of Eighteenth-Century Naval Architecture - Chapman F.H...
The Seventy-Four Gun Ship Vol.IV - Manning & Shiphandling - Boudriot J. [1988, PDF]
Le Francois - Vaisseau 5eme Rang 1683 - Lemineur J.C. [2000, PDF]
The time now is: Today 15:12
