zxc ®   22-Oct-2014 12:23
Essential english for marine engineers
Year: 19xx
Author: -
Genre: -
Publisher: -
Number of pages: 155
Description: The diesel engine is an internal combustion engine which ignites the fuel by injecting it into hot high pressure air in a combustion chamber. The diesel-engine has either a four - stroke or a two1- stroke cycle. A stroke is a travel of the piston betweeh its extreme points.
The four stroke cycle consists of inlet (or suction), compression, power (or working stroke) and exhaust. This cycle is completed in two revolutions of the crankshaft. At the top dead centre (TDC) the inlet valve opens and fresh air is drawn in as the piston moves down -suction stroke. At the bottom dead centre (BDC) the inlet valve closes and the air in the cylinder js compressed as the piston rises-compression. Fuel is (injected as the piston reaches TDC ami combustion takes place producing very high pressure ip the gases. There gases force the piston down and at BDC the exhaust valve opens. The final stroke is the exhausting of the burnt gases as the piston rises to TDC
Глава 1. Дизельные установки / Diesel engines
Глава 2. Котлы / Boilers
Глава 3. Насосы / Pumps
Глава 4. Вспомогательные механизмы / Auxilaries
Глава 5. Палубные механизмы и оборудование / Deck machinery and equipment
Глава 6. Рулевая машина / Stearing gear
Глава 7. Валопровод и винты / Shafting and propellers
Глава 8. Бункеровочные операции / Bunkering operations
Глава 9. Заказ запчастей и снабжение / Ordering spare parts and general supllies
Глава 10. Ремонт / Repairs
Глава 11. Машинная команда. Обязанности. Несение вахты. Периодичные проверки механизмов в целях безопасности / Engine department. Duties. Watchkeeping. Periodic safety routines
Essential english for marine engineers.pdf
Download [8 KB]
СергейСергеевич   03-Apr-2015 16:20
Добрый день!
Подскажите, пожалуйста, нет ли на трекере или в сети аналогичной книги, но для инженеров-конструкторов корпуса судна? Очень нужна! Спасибо!!
IgorKul13   28-Oct-2015 13:26
когда будет в раздаче, очень много материала который нельзя скачать
Reeds Engineering Knowledge - Instruments and Control Systems for Deck Officers - Embleton, William…
Captain’s QUICKGUIDE - Nigel Calder [2007, PDF]
Процессы в дизельном двигателе - Wartsila / Diesel process - Wartsila [MP4]
Slow Speed Diesel Engines - S. H. HENSHALL B.Sc(Eng) C.Eng [1987, PDF]
Marine engines & Propulsion systems - Ranger Hope [2008+2015, PDF/DOCX]
Class One Engineering Knowledge, South Tyneside College [2007, PDF]
Экипаж 2002 - Тест для судомехаников
The time now is: Today 15:54
