gillnumil ®   26-Aug-2019 06:45
Lubricant storage and dispensing guidelines
Year: 2013
Author: Shell Marine
Publisher: Shell Marine
Pages count: 6
Description: This document covers the three areas involved in the storage and dispensing of packed lubricants. It does not cover bulk lubricant storage.
Those areas are:
1) Correct storage of lubricants: location, design and practices
2) Lubricant shelf life: Determining shelf life is not an exact science, as shown by the varying advice from different “reputable sources”. This document covers the temperature range from 5–25°C. Outside this range, extra precautions may be necessary and the shelf life of certain types of lubricant will change.
3) Dispensing the lubricant involves getting the lubricant safely from the store into the piece of machinery where it is needed in the most appropriate way.
Additional info: To find out more about our range of marine fluids for operations in environmentally sensitive areas, please contact your local Shell representative or email to [email protected].
1) Correct storage of lubricants.
2) Lubricant shelf life.
3) Dispensing the lubricants.
lubricantsstorageanddispensingguidelines.pdf
Shell Rapid Lubricants Opica User Guide - Shell Marine [2014, PDF]
Delivery Guidelines - Shell Marine Products - Shell Marine [2014, PDF]
Getting Results Fast - A guide to Shell Rapid Lubricants Analysis - Shell Marine [2014, PDF]
SHELL Fuel and Lubricants Catalogue - Shell [2014, HTML]
Marine Lubricants Pocketbook - Shell Marine [2017, PDF]
LNG Operations in Port Areas - Essential Best Practices for the Industry - SIGTTO [2003, PDF]
Barge Stability Guidelines - Maritime New Zealand [2006, PDF]
Castrol Caremax - Safety Data Sheets - Castrol Marine [2016, PDF]
Lubricants and Hydraulic Fluids - U.S. Army Corps of Engineers [1999, PDF]
Guidelines on Main Propulsion Shafting Alignment - IACS [2025, PDF]
The time now is: Today 15:07
