Punky ®   15-Apr-2019 15:45
GPS Utility Standard edition Version 5.18
Year: 2011
Version: 5.18
Developer: A S Murphy
System Requirements: WIndows 7,8,10 x32 x64
Crack: Included
Description: GPS Utility is a stand-alone application for managing, manipulating and mapping waypoint, route and trackpoint information.
Please see the Conditions of Use.
The main features are:
1. Basic Edit of GPS information
2. Sort waypoints
3. Filter waypoints and tracks
4. Convert coordinates between map datums
5. View different coordinate formats. (including UTM/UPS, British, Irish, German, Swiss Grids)
6. Downloading/Uploading to Garmin, Magellan, MLR + other GPS receivers **
7. Load selected (Marked) waypoints or tracks to GPS receiver.
8. Produce track and route leg distance and time information
9. Automatically generate Waypoints and Routes from tracks
10. Read/Write files in several formats
11. Print GPS information
12. Map GPS information
13. Print the information as a bitmap
14. Export map as bitmap
15. Overlay GPS information on Bitmaps
16. Digitise GPS information from Bitmaps
17. Real time current position (create tracklog and Moving Map display).
18. Position console show current position speed etc.
19. Import data from Microsoft's AutoRoute Express
20. Import MapsOnUs, MapBlast and Green Flag routes
21. Import and export (with limitations) to DBF and MapInfo files.
22. Import and export Autocad (DXF) and several other file types - see File Formats
23. Set PC clock from GPS time.
24. Generate Search Patterns round a waypoint
25. Deal with up to 65000 waypoints and 65000 trackpoints (registered version)
Additional info: Install and after copy "Gpsu518.exe" from crk.rar to : C:\Program Files (x86)\GPS Utility
Download [4 KB]
Arcan   15-Apr-2019 16:02
Facturamea83, Your poster is very poor, I added mine.
What the reason you include so many empty lines in the description?
Remove them, please.
Arcan   15-Apr-2019 16:14
Facturamea83, And as I can see - one screenshot of "Waypoint" program ?
Punky ®   15-Apr-2019 18:14
Arcan, Look up on the left corner, is not waypoint. Is a .rt3 route format imported in the software which can be exported in many other formats with the help of gpsutility
Arcan   16-Apr-2019 13:25
kin99, No, there are 6 seeders are ready to give this file to you. Problems somewhere from your side. Try to use VPN.
Punky ®   16-Apr-2019 13:33
kin99, You have o reputation, you need 2 to download this torrent.
Tore62   16-Sep-2019 20:15
Punky,
Hello.
I need this software, But have no Reputation.
Kan you help me , Please......
D_E_A   22-Dec-2020 18:09
56767Punky,
Hello.
Punky ®   24-Dec-2020 02:47
Upload something for public interest, tell me when you dine and I will thank you. Then you will be able to downlowd.
With regrads!
Furuno Dual GPS GP-90-DUAL - Furuno [2003, PDF]
VovSoft Container Loading Calculator v.1.5 - Vovsoft [2024]
Maris ECDIS900 Operator Manual - Navico Holding AS [2017, PDF]
SAAB Combined Transponder System R4 AIS and Navigation system Installation Manual - SAAB [2010, PDF]
The GPS Receiver - UIC [2014, PDF]
MarineTraffic v.4.0.46 - MarineTraffic [2023] [Android]
MarineTraffic Mod Apk Latest Update v.3.9.56 - Marine Traffic [2020] [Android]
Nautical Calculator Pro v.9.2.0 - Giacomo Gabriele [2022] [Android]
GpsGate Client For Windows v.2.6.0.402 - Franson GPS GATE [2018]
EIVA Mobula Pro v.4.7.0 - Eiva [2022]
  • Topic closed
The time now is: Today 17:13
