vacendak ®   04-Jan-2019 21:31
Refrigeration For Pleasureboats
Год выпуска: 1991
Язык: английский
Автор: Nigel Calder
Жанр: Техническая литература
Издательство: McGraw Hill
ISBN: 0-07-157998-2
Количество страниц: 159
Описание: Refrigeration for Pleasureboats explains how the cruising sailor can acquire the amenities—even the necessities—of an efficient onboard refrigeration system. Whether you're off for two days or two years, you must balance the highest possible cooling capacity with the lowest possible energy consumption. Calder explains clearly and logically how and why refrigeration components work, how to keep them working efficiently and economically, and what to look for when something goes wrong.
Boat refrigeration systems are phenomenally expensive. A modest refrigerator/freezer system, professionally built and installed, can cost more than $4,000. Yet these units can still have unpleasant side effects—such as killing the boat's batteries. Refrigeration for Pleasureboats provides all the step-by-step information an amateur needs to design and build a custom refrigeration unit that will cost far less than half the price of an off-the-shelf unit and will likely run better with far less drain on the batteries. With Calder's maintenance and troubleshooting tips, you'll be able to keep it running for years to come and keep those ice cubes tinkling in that frosted glass.
Nigel_Calder - Refrigeration_For_Pleasureboats RDC 1991.pdf
Download [17 KB]
Captain’s QUICKGUIDE - Nigel Calder [2007, PDF]
Refrigeration and Air Conditioning - W.F. Stoecker, J.W. Jones [1983, PDF]
The International Marine Book Of Sailing - Robby Robinson [2009, EPUB]
Piping Systems Manual - Brian Silowash [2010, PDF]
How Boat Things Work - Charles Wing [2007, PDF]
Marine diesel engines: Maintenance, Troubleshooting, and Repair - Nigel Calder [2007, PDF]
Поиск неисправностей в электронике / Electronic Troubleshooting - Dan Tomal,Neal Widmer [2007, DjVu]
The Boatowner’s Guide to Corrosion: A Complete Reference for Boatowners and Marine Professionals - E...
Nigel Calder’s Cruising Handbook: A Compendium for Coastal and Offshore Sailors - Nigel Calder [2001...
This Old Boat - Don Casey [2009, PDF]
The time now is: Today 16:37
