MGM ®   29-Dec-2018 23:23
IMSBC Code
Year: 2018
Author: IMO
Genre: Convention (rules)
Pages count: 652
Description: IMSBC Codе Edition 2018 with incorporating amendment 04-17 and supplement
The IMSBC Code, adopted on 4 December 2008 by resolution MSC.268(85), entered into force on 1 January 2011, from which date it was made mandatory under the provisions of the SOLAS Convention. The present edition incorporates amendment 04-17, which may be applied from 1 January 2018 on a voluntary basis, anticipating its envisaged official entry into force on 1 January 2019.
This publication also presents additional information that supplements the IMSBC Code, such as the Code of Practice for the Safe Loading and Unloading of Bulk Carriers (BLU Code, including BLU Manual) and Recommendations on the safe use of pesticides in ships applicable to the fumigation of cargo holds. The International Maritime Solid Bulk Cargoes Code and supplement is commended to Administrations, shipowners, shippers and masters and all others concerned with the standards to be applied in the safe stowage and shipment of solid bulk cargoes, excluding grain.
See the book contents pages
SerTan   30-Dec-2018 14:42
Good upload! Thanks for the job!
But why did you put it into Others (not maritime) ???
As far as it is marine low, that is VERY marine thematic!
And as it is the CODE, it should be written at Genre: Convention (rules) but not Dictionary.
Anyhow as release has been already CHECKED and it is not possible to be corrected from your side now, I made the change and moved it into the right forum.
But pls choose right place for an upload for the next time .
Может по пиву?
6
alexn23   31-Dec-2018 01:05
В этом издании странная ошибка.
На стр. vi приведена часть оглавления из МК МПОГ (IMDG Code).
There is a strange error in this book.
On the page vi there is a part of Contents from IMDG Code.
SerTan   01-Jan-2019 14:58
alexn23, Да, действительно - присутствует ненужная страница... Видимо при компоновке страниц случайно залетела с другой отсканированной книги))) Такое иногда бывает - мы все люди))) Удалите любым ПДФ редактором - и все дела! Может по пиву?
Судя по этой залетной странице - мы возможно скоро увидим новый IMDG Code (2018) от того же автора)))
IMSBC Code and Supplement (08-25) 2025 Edition - IMO [2025, PDF]
IMSBC Code (Incorporating Amendment 03-15 and Supplement) - IMO [2016, PDF]
International Maritime Solid Bulk Cargoes Code (lMSBC Code) - IMO [2009, PDF]
IMSBC code 2020 (incorporating amendment 05-19) - IMO [2019, PDF]
IMSBC Code and Supplement (Incorporating Amendment 07-23) 2023 Edition - IMO [2023, PDF]
IMSBC Code - Circ.462(101) - IMO [2019, PDF]
BLU Code - Code of practice for the safe loading & unloading of Bulk Carriers - IMO [2011, PDF]
MARPOL Consolidated Edition - IMO [2011, PDF]
SOLAS CONSOLIDATED EDITION 2020 - IMO [2020, PDF]
IMDG Code Supplement 2024 Edition - IMO [2024, PDF]
  • Topic closed
The time now is: Today 21:25
