virtual ®   27-Dec-2018 21:37
Safety of pressure systems, Pressure Systems Safety Regulations 2000 - Approved Code of Practice and guidance, Second Edition
Year: 2014
Author: HSE
Edition: 2014
ISBN: 978 0 7176 6644 7
Pages count: 69
Description: Approved Code of Practice
This Code has been approved by the Health and Safety Executive, with the consent
of the Secretary of State. It gives practical advice on how to comply with the law. If
you follow the advice you will be doing enough to comply with the law in respect of
those specific matters on which the Code gives advice. You may use alternative
methods to those set out in the Code in order to comply with the law.
However, the Code has a special legal status. If you are prosecuted for breach of
health and safety law, and it is proved that you did not follow the relevant provisions
of the Code, you will need to show that you have complied with the law in some
other way or a Court will find you at fault.
Guidance
This guidance is issued by the Health and Safety Executive. Following the guidance
is not compulsory, unless specifically stated, and you are free to take other action.
But if you do follow the guidance you will normally be doing enough to comply with
the law. Health and safety inspectors seek to secure compliance with the law and
may refer to this guidance.
l122.pdf
Download [902 B]
Dangerous substances and explosive atmospheres - HSE [2013, PDF]
Dangerous Goods in Harbour Areas Regulations (UK) - HSE [2016, PDF]
Safety in docks - HSE [2014, PDF]
Instructions for the Guidance of Surveyors on the ISM code for the safe operation of Ships and for…
Code of practice on safety and health in ports - ILO [2017, PDF]
Guidelines for FLag State inspections under the MLC - ILO [2021, PDF]
Shipyard Industry Standards - OSHA [2015, PDF]
Explosives Regulations - Safety & Security provisions - HSE [2014, PDF]
A Guide To Good Practice On Port Marine Operations - UK - Department For Transport [2013, PDF]
2021 OSHA Shipyard Industry Standards - Shipyard Industry Standards - OSHA [2021, PDF]
The time now is: Today 14:37
